SOLVED PHPBB 3.0.9 Released - ETA On Styles Update?
Subject: PHPBB 3.0.9 Released - ETA On Styles Update?
Just wondering if you had an ETA on updating at least Rainbow Pearl to 3.0.9 and if you would be able to release the changes you made to it to get it to 3.0.9.
I have a lot of mods on the style for additional features, and it would be helpful to know what I can do to update my Rainbow Pearl to 3.0.9.
Thanks!
-Eric
Subject: Re: PHPBB 3.0.9 Released - ETA On Styles Update?
Hi megamav,
I guess "ASAP" won't satisfy you :mryellow:
Knowing MG a little and the fact that he happened to mention the need for updating styles to me yesterday... it won't take verry long before the updates will be posted in the release threads.
Usually MG will release all updated styles at the same time (both here and in the mod database at phpbb.com)
In short.. there is no ETA but my guess is it won't take very long :wink:
The right answer is... SUSPANCE...
TONIGHT! :mri:
I'm checking the last files and then I will update here the new versions.
Stay tuned.
Darn, I was almost right :oops: :LOL:
Almost is still not perfect! :mri:
Subject: Re: [SOLVED] PHPBB 3.0.9 Released - ETA On Styles Update?
Hi, just wanted to follow up, im upgrading in a couple of weeks.
What are the changes to the theme? between 3.0.8 and 3.0.9?
Easy enough to copy and paste a few things?
Hi megamav,
I haven't updated myself because I'm waiting to be at a good stable point in my code :oops:
but according to the release notes (after tracing some logic in those!) it should be the following files that need to be updated:
Release Notes wrote:
- Files updated:
# style.cfg
# imageset.cfg
# template.cfg
# theme.cfg
# stylesheet.css
# attachment.html
# login_body.html
# mcp_topic.html
# memberlist_im.html
# overall_footer.html
# overall_header.html
# posting_body.html
# posting_buttons.html
# posting_smilies.html
# quickreply_editor.html
# searchbox.html
# simple_footer.html
# simple_header.html
# ucp_pm_viewmessage_print.html
# viewtopic_body.html
# viewtopic_print.html
*NOTE to MG:
The new versions still are a bit confusing:
- Release notes in 1.6.7 miss the updated files from 1.6.6 (in our release thread and at phpbb.com)
- at the styles page of IcyPhoenix (http://www.icyphoenix.com/styles/styles.php?cat_id=phpbb3) the styles miss the contrib folder (and also no agreement before download)
*I know why this happened but it s a bit confusing
*NOTE to MG:
Thanks for reporting... I'll have a look
Generation Time: 0.0824s (PHP: 23% SQL: 77%)
