[Request] Adding Link Tabs To Mg_autumn
Subject: [Request] Adding Link Tabs To Mg_autumn
The phpBB2 Inspiration template developed by http://ggweb-fr.com/phpbbfre/ (GilGraf) for Categories Hiearchy (Ptirhiik) refers.
I currently use mg_autumn on a phpBB3 board at http://www.galahscorner.com.au/gumtree/index.php and have attempted to use the code from Inspiration to add Link Tabs to mg_autumn however, my knowledge of phpBB3 is at this stage pretty limited.
I would like someone to develop the Link Tabs as an add on to phpBB3 templates if they could please as I think they look pretty good and when one does not use a portal system, adding a few links via Tabs is a good idea which I have already done on another phpBB2 (CH) board at http://rodneyangell.com/forum/portal.php
There are two possiblities with such an add on and one is that the links could be turned on/off/edited in ACP or simply a "Find/Replace/After add/ text document with the necessary phpBB3 edits to install it, with the links being editable in overall_header.html
I hope someone can find the time to work this into a hack for phpBB3 thanks.
Subject: Re: [Request] Adding Link Tabs To Mg_autumn
You can try integrating this:
http://www.phpbb.com/community/viewtopic.php?f=74&t=577293
Thanks for that.
I will have a play with the code to see how it works out and let you know.
Generation Time: 0.1094s (PHP: 16% SQL: 84%)
