Re: I Want To Remove " Post A Reply " Box
Hi again Tremendous,
I have a feeling you added an old mod for phpbb 3.0.0 but i don t see a link to either the mod or your board to view
this one maybe?
Author rxu
Version 1.6.7
phpBB Version(s) 3.0.0
Last updated Mon Mar 10, 2008 10:59 am
as you can see this is updated last loooooong time ago and not for the latest phpbb version
Usually when you have problems with an installed mod you should ask questions in the mod developers thread (and/or read the release thread very carefully for known problems) ..because they would know best what this mod does exactly
IMHO it would be easier to add bbcodes to the included quick reply in phpbb 3.0.8 and I even dare to asume that there is a more up to date solution for this in the database at phpbb.com
It's quite hard to give advice on this without installing it myself to see what it does exactly (like if it is added in
ACP to handle settings and how)
Have you tried to disable the original phpbb 3.0.8 Quick Reply in
ACP already?
