Post New Post Why Are There Still New Posts? Board Bug
On my forums;
 Even though i have clicked the "mark all items as read". The site still show them as new.
see
( Home • Forum • Rules • Control Panel • New (162) •   Search • FAQ • Log out)
It shouldn't be that way.
I have the same problem when i click "View posts since last visit (163)" then i read which interest me then select all, click mark as read, but instead i am forwarded to the search page while all of them should have been marked as read and i should have been forwarded to the next page.
Any help
oscarxpSend private message
Post Re: New Post Why Are There Still New Posts? Board Bug
no luck yet
Just use this: System UPI2DB. .
My 2 IP Forums:
what do you mean by System UPI2DB.
oscarxp wrote: [View Post]
Go to your ACP -> Configuration -> Unread Posts => Voila - you are in UPI2DB Configuration
from there you can set how unread/read posts are managed.
I find that even when you set new posts as read I have to close the browser for the settings to take effect!
Mayby this is something for MG to look at
jzSend private message
Yes... unfortunately some infos remain linked to the last access time... I'll try to check it when I have some free time... I think it is a minor issue.
