[SOLVED] Change Warnings Images To Text.
Subject: [SOLVED] Change Warnings Images To Text.
Is there any way to change the warning images to just like "Warnings: 1" etc ???
Subject: Re: Warnings Text??
Can you help me do the changes?
Maybe you can post a How to in the How to forum!
Looking forward to this!
Try this on viewtopic.php
$card_img .= ($user_warnings) ? '<img src="'.(( $user_warnings < $board_config['max_user_bancard']) ?
$images['icon_y_cards'] . '" alt="'. sprintf($lang['Warnings'], $user_warnings) .'" title="'. sprintf($lang['Warnings'], $user_warnings) .'" />' :
$images['icon_r_cards'] . '" alt="'. $lang['Banned'] .'" title="'. $lang['Banned'] .'" />') : '';
$card_img .= ' ';
$card_img .= ' ';
thats my darling!!!
thank you so much.... but first let me try if it works or not!
no still doesnt work....the images show up!
i dont want the images to show up....i want it to be like the original mod like in text Warnings: 1
Zuker wrote: [View Post]
Check this topic
http://www.superzuker.com.ar/icy/viewtopic.php?p=62#p62
See the test user?
It says Warnings: 1
It's working ;)
See the test user?
It says Warnings: 1
It's working ;)
Subject: Re: [SOLVED] Change Warnings Images To Text.
I tried this code on my test board....
but the problem is it shows
Warnings 1 for 1 warning ------ ok thats correct
but for 2 warnings it shows this thing twice!
Warnings:2 Warnings: 2 and so on...
whats wrng here? :(
And how about if i dont want the red card to show if the user reaches the max warnings....when he/she does...it should show the no. of warnings.
Please help Zuker!!
whats wrng here? :(
Please help Zuker!!
Was that for me? Then you are wrong...i dont know any spam account neither i know how to create one! :shock:
it was registered using the same ip adress of your account
so the same person has unknown OS and unknown browser as has Win XP and FF2, (and that's just public info).
I dont know....i live in a university...all pc's have same public IP's. I dont have time to use my own account...how can u expect me to make other?!?
Any ways....this little patch u gave doesnt work and i have that problem which i wrote in my post above.
Please try that on your test board....I really need this thing working...
Generation Time: 0.0685s (PHP: 30% SQL: 70%)
