I Can't Insert XS News From Control Panel.
Subject: I Can't Insert XS News From Control Panel.
Please help me. my news is ok but button insert news in xs news panel don't work, only refresh page.
Link
Subject: Re: I Can't Insert XS News From Control Panel.
Hello Xela :wink:
OPEN---> templates/common/xs_mod/tpl_news/news_list_body.tpl
  1. name="addxml"
  1. name="addnews"
thanks very much!!! it's possible to use bbcode or html in news panel?
es.
  1. [marquee direction=left]Risultati della giornata: :arrow:[url=http://www.birramoretticalcio.it/view.jsp?id_p=36017921][color=darkgreen] Barbetta - [b]Olimpia mokaor vercelli [/b]0 - [b]4 [/b][/color][/url]:arrow:[url=http://www.birramoretticalcio.it/view.jsp?id_p=36030724][color=red] Bella Marina - [b]At. Iberia Dep. [/b]0 - [b]2 [/b][/color][/url]:arrow: [url=http://www.birramoretticalcio.it/view.jsp?id_p=36022476][color=darkorchid] [b]Juventus[/b] - S.S. Montecalvario[b] 2[/b] - 0[/color][/url] :arrow:[url=http://www.birramoretticalcio.it/view.jsp?id_p=36042337][color=darkblue] [b]Juventus[/b] - A.C. Campora[b] 3[/b] - 0[/color][/url][/marquee]
  2.
  3.
and why in update I loose the possibility to visualize correctly html code in posts? in phpbb2 I had this code
  1. <object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/_SdoTxdJsMA"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/_SdoTxdJsMA" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
  2.
now I visualize also code. I need to have html support because I use many tags ex. iframe
sorry for my bad english!
thanks , cristina :mrviolet: :mrorange: :mrblue:
:v:
noone?
You can use HTML in news.
Regarding HTML, some HTML tags have been disabled for security issues... you can insert those video using the GOOGLEVIDEO or YOUTUBE BBCodes which are already included in Icy Phoenix.
I can't use html in news panel! It don't work
sorry but panel "permitted tag" is disable in your version?
the code I need is on up topic and I also need the tag b,i,u,pre,p,tr,td,table,div,span,th,iframe,object,param,embed,
please help me.....aiutatemi per favore
Please be patient.
Use a CMS block instead of using news, so you can use any HMTL code you wish.
Please, change your avatar because it contains offending words in Italian.
Generation Time: 0.0631s (PHP: 30% SQL: 70%)
