Problema Restoring My Forum
Subject: Problema Restoring My Forum
i update my forum to th last version of icy
when i go te restore y put start restore and says this
Error importing backup file
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'read int(1) NOT NULL, time int(10) NOT NULL )' at line 3
CREATE TABLE ipt_force_read_users( user varchar(255) NOT NULL, read int(1) NOT NULL, time int(10) NOT NULL )
Line : 1392
File : admin_db_utilities.php
what can i do?
bye :mrviolet:
Subject: Re: Problema Restoring My Forum
The phpbb feature for backuping database is not a good choise. You better use another tool like phpmyadmin ;)
yes but i can`t because i erase all my forum
But in what way do you update your forum?....
Did you read the docs for update procedure?
is the asme likle
I have a new forum with las icy i want to restore some data that i backup before and says me that
bye
I don't understand your english. Sorry
I think that it will be better to ask in phpbb-es.com
Because translators not always work fine ;)
Hellow, Plaease, helpme... I installed a forum and when try restoring my forums it happens error. (page can't be found)
Thanks for your helpme!! :D
That is not the correct way to upgrade... you need to run the update script on your current DB.
If you can't speak English, but you can speak Spanish, please ask support in the Spanish support forum.
look the problem is this
i want to restore some data,that i have backup before....and icy phoenix says me that when i restore it...
what i have to do?
Generation Time: 0.1658s (PHP: 11% SQL: 89%)
