Error After First Installation
Subject: Error After First Installation
Yesterday i`ve installed Icyphoenix for the first time. I`ve set during the setup the permission via ftp (chmod) for announced files.
When i will Login BTW. when go on the IndexPage i`ve got the following error message
onlength is set undersize! Maybe thus you will always logged out of the Forum before you can correct the setting.'; $lang['ctracker_gmb_pu_3'] = 'CBACK CrackerTracker - Misconfiguration
The Scriptpath begins and/or ends either not with a Slash (/www/) or doesn't only compose of the Slash (/)!'; $lang['ctracker_gmb_pu_4'] = 'CBACK CrackerTracker - Misconfiguration
The Servername doesn't end with a Slash (/) !'; $lang['ctracker_binf_spammer'] = 'The Spam Security System is watching you. You have reached your maximum number of posts within %s seconds. When you try to write withing %s seconds another post, your account will be blocked!
Please wait. Sorry to take your time, but this is necessary for safety reasons.'; $lang['ctracker_binf_sban'] = 'The Spam Block System has banned your account because you have been identified as a spammer.'; $lang['ctracker_sendmail_info'] = 'Due to safety reasons you are only allowed to send an e-mail every %s minutes.'; $lang['ctracker_pwreset_info'] = 'Due to safety reasons it is not possible to send a new password every %s minutes. Please contact the administrator if you have trouble!'; $lang['ctracker_vc_guest_post'] = 'Visual Confirmation for Guests'; $lang['ctracker_vc_guest_expl'] = 'Please enter the following code before sending your post. For guests this is neccessary due to Spam Security reasons.'; ?>
Warning: Cannot modify header information - headers already sent by (output started at /www/htdocs/xxxxxxx/icephoenix/language/lang_english/lang_cback_ctracker.php:453) in /www/htdocs/xxxxxxx/icephoenix/includes/page_header.php on line 1213
Warning: Cannot modify header information - headers already sent by (output started at /www/htdocs/xxxxxxx/icephoenix/language/lang_english/lang_cback_ctracker.php:453) in /www/htdocs/xxxxxxx/icephoenix/includes/page_header.php on line 1215
Warning: Cannot modify header information - headers already sent by (output started at /www/htdocs/xxxxxxx/icephoenix/language/lang_english/lang_cback_ctracker.php:453) in /www/htdocs/xxxxxxx/icephoenix/includes/page_header.php on line 1216
I don`t know what mistake i`ve made during the installation
Thank you for help
LGD irk
Subject: Re: Error After First Installation
Make sure you have inserted the corrected path while installing... or try to edit it directly in phpbb_config table.
Thanx - but i `dont find a table like that.
I try to install for a second time but after intalling i´ve got the same error.
LG Dirk
Hi, DirkDaF
What Mighty is suggesting is that you edit script_path in MySQL. Normaly it is in phpbb_config table, but it might be also under name ip_config. Try looking for that one.
Generation Time: 0.1171s (PHP: 15% SQL: 85%)
