A Weird Problem In My Forum
Subject: A Weird Problem In My Forum
Hi everyone, nice too meet you.
the problem is this: I follow step by step the install and permision and delete /install and /contrib folders like in the instructions, when I want to see my forum :shock: this is the error:
(I take a pict from the error for more help)
My host is free in h**p://members.lycos.nl/cyberengels/
I install de fix files too...
I want to know what is the fix on this or what I do about this
:( realy I need help please ... I want some help to anyone :cry: please please please :cry:
----UPDATE-----
I REinstall the MODS folder and this dont fix the problem :cry:
Subject: Re: A Weird Problem In My Forum
Try uploading again the mods folder
z3d0 wrote: [View Post]
Thx
I doed that, upload again the folder mods but dont fix this :cry:
Maybe i dont know may be is the host server? i dont know how fix this.
the forum works
http://members.lycos.nl/cyberengels/forum.php
only you dont have the file
reupload it
mods/netclectic/mini_cal/mini_cal.php
casimedicos wrote: [View Post]
the forum works
h**p://members.lycos.nl/cyberengels/forum.php
reupload it
yes, the forum works, I reupload all files of mods/ but the same problem is the same in h**p://members.lycos.nl/cyberengels/index.php not fixed anything
deactivate block calendar in ACP
check if in the folder "mods" there's the mini_cal, in case download again phpBBXS, unzip it and upload the file
Subject: Respuesta: A Weird Problem In My Forum
Probably a problem with your hosting...
Rename mods/netclectic/mini_cal/calendarSuite.php to mods/netclectic/mini_cal/calendarsuite.php
Beware of difference between calendarSuite.php and calendarsuite.php
Generation Time: 0.6924s (PHP: 3% SQL: 97%)
