Change Time Management
Subject: Change Time Management
How can i set Time management: DST enable by the server? i have to set it for all users
Subject: Re: Change Time Management
After having set it in the Board Settings, you should manually apply it to all user if you want to force them.
You can run an SQL similar to this one:
I can't remember the name of the field... but you will easily find it in the db.
Generation Time: 0.0972s (PHP: 16% SQL: 84%)
