Hello everybody!!
I have a dude with the new patch Icy Phoenix 1.1.0.15c...
I have download this patch, but the spanish language isn't included... in the language directory is only english language...
There are the spanish traduction?
Thanks for your replies!!
Greets!!
PD: Sorry for my bad english!!
Dude With The New Patch
Subject: Re: Dude With The New Patch
dllrsoft, the spanish language for 1.1.0.15 is the same for 1.1.0.15*
Thanks for your reply novice programmer, but the patch make changes in two files of the language.
This files are: lang_main.php and lang_main_settings.php
Greets!!
Greets!!
I imagine that The KuKa, Janu and SuperN will be trying to traduce it.
I also think that if they have traduced it, it will be able to download from www.phpbb-es.com, as they administrate/moderate there.
novice programmer wrote: [View Post]
novice programmer, I have search in phpbb-es.com, of course...
I also go to the annuncement of this patch in phpbb-es.com, but the links go to the download of this page... sorry.
I remember that in the icy phoenix 1.1.0.15b patch, zuker make the traduction...
Someone know if Janu is working in this traduction?
Thanks for your reply!!
Greets!!
Greets!!
there weren't new lines added in last patch, only a couple of lines were fixed.
patch updated in the spanish translation topic :mricy:
Zuker, where is the spanish translation topic?? I have search but I don't find it... :?
Greets!!
Greets!!
Zuker, I'm sorry, but I can't find it... :?
What do you want to say with "inside the first post"?
In the spanish post of Icy Phoenix 1.1.0.15 or in the post of Icy Phoenix 1.1.0.15c?
Greets!!
Greets!!
I konw i dont want force anybody to upgrade.
This problem has been already solved as long as i see and the latest version is RC 1, this last part is pointing to new icy users, so i think this topic not needed to continue open.
Unlock it if you think it is needed
Zuker wrote: [View Post]
Generation Time: 0.338s (PHP: 6% SQL: 94%)
