Can Anyone Help With This?
Subject: Can Anyone Help With This?
I am using the latest version of bigdump.php. My db is about 34MB and it gets to this and errors out:
Error at the line 19301: );
Query: CREATE TABLE phpbb_force_read_users(
user varchar(255) NOT NULL,
read int(1) NOT NULL,
time int(10) NOT NULL
MySQL: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'read int(1) NOT NULL, time int(10) NOT NULL )' at line 3
Any ideas? Can I just delete this entry?
-D1-
Subject: Re: Can Anyone Help With This?
Check this post
http://www.icyphoenix.com/viewtopic...ghlight=bigdump
Generation Time: 0.1624s (PHP: 10% SQL: 90%)
