Recent Topics- Number Of Forums To Exclude [RESOLVED]
Subject: Recent Topics- Number Of Forums To Exclude [RESOLVED]
In the ACP > SQL Reduction > Recent Topics there is an option:
Forum To Exclude
Please, insert the IDs of the forums to be excluded in Last Messages Box (you can separate by comma each forum ID).
Can anyone please tell me how to increase the number of forum IDs you can insert here, as there are loads more I want to exclude than the space in the text box allows?
Subject: Re: Recent Topics- Number Of Forums To Exclude
open and edit this line
<input class="post" type="text" maxlength="255" size="40" name="last_msgs_x" value="{LAST_MSGS_X}" />
in templates/common/board_config_queries.tpl
you have to check if that field on db support more than 255 chars
ps: do you have more than 70 forums to exclude :shock: ?
Zuker wrote: [View Post]
I can't find a database entry called 'last_msg'
Is it called something else, and what should I change the db entry to so that it can support more than 255 chars ?
P.S. Yes I have 228 forums to exclude. And yes, I have loads more forums altogether.
tc1967uk wrote: [View Post]
What´s your webpage :shock: :shock: :shock: ?
How many forums do you have on it :shock: :shock: ?
What kind of server do you have?
What hosting company gives you the hosting?
Can anyone help with this please?
can i have a link please?
No, sorry. I'm not going public with my site for quite a while yet.
My forum's make-up isn't the issue here. Can someone help with this please?
Read all the posts, please.
If you read my post, you'll see that I did, and asked for help with the above. Can anyone clarify what I should be looking for and where?
PM your site and we will help you
if you change this 255 with 500 for ex
works?
if don't explore your database on phphbb_config table and check this field
last_msgs_x
Try to add them there directly
Subject: Re: Recent Topics- Number Of Forums To Exclude [RESOLVED]
Thanks for clarifying what to change, Zuker. It seems to have worked.
you are welcome.
Generation Time: 0.1009s (PHP: 24% SQL: 76%)
