I found a bug in the Forum [news] Block. On my portal start page I have the block forum [news] active. But instead of topics marked as News, every new topic is displayed without being marked as Important or annoucement.
How can I fix it?
Forum [news] Block Bug
Subject: Re: Forum [news] Block Bug
It's a same problem for me, ever since...may be my hosting web is a principal cause ? I don't know...
I wait for a solution from what one...
Thanks in advance.
Thanks in advance.
Yes it is. Where can I give you full CMS Rights? User Test is now Content Manager and has a normal user group but cannot access the cms :S
novice programmer wrote: [View Post]
Corleone, you haven´t got any problem with your news block.
Note: The news aren´t set trought the important or sticky. The option below it says News category. Set the box to regular post
Yes novice programmer i know...
but I reinstall my forum...
Thanks you for giving me help
Ok I will try but if this will work? Normally the files would be the same.
I re-uploaded all block files for ca_aphrodite, clear style cache and recompile the cache.
The Problem still exists.
Do you have any other idea? Its not ok with reuploading the block files.
Generation Time: 0.3664s (PHP: 8% SQL: 92%)
