SOLVED Nav Block Nested In Sitemap Block
Subject: Nav Block Nested In Sitemap Block
I upgraded one of my forums from 1..1.0.15d to 1.1.9.24 RC2 and for some reason my Nav block is nested in a sitemap block. At first the Nav links were not working so I re-uploaded a bunch of files and the links are now working, but the nesting problem is till there. Is there a file that I can replace, and if so, where is it?
The page is located at http://afreecountry.com/phpBB2/index.php. My other two forums do not have this problem, but they were not upgraded from 1.1.0.15d as this one was.
Subject: Re: Nav Block Nested In Sitemap Block
Hello
In CMS the nav block you must set no
nav
Pepi
Thank you very much. That fixed it. :mricy: :mrgreen: :mrblue: :mrorange: :mrviolet: :mryellow:
Generation Time: 0.6696s (PHP: 3% SQL: 97%)
