Icy Phoenix 1.1.10.25 RC3 - Bugs Tracker
Goto page 1, 2, 3, 4  Next
Subject: Icy Phoenix 1.1.10.25 RC3 - Bugs Tracker
Please, post here all possible bugs tfir Icy Phoenix 1.1.10.25 RC3.
Thx in advance.
Subject: Re: Icy Phoenix 1.1.10.25 RC3 - Bugs Tracker
Hello.
I have a white page when I install this version.
Just after of subit the information in the install form.
On ACP
Configuration > Clear cache
the table appear three times
clear_chache
a function of the ctracker is disable
i cant activate the function with the ctracker settings part in the ACP
Filename: Zwischenablage01.jpg
Filesize: 113.5 KB
Downloaded: 263 Time(s)
FTR doesn´t work
if i edit or add a new link in the dynamic menu it nothing changes in the dynamic menu
Sorry Im New Here
well im using the las version of icy and my ctracker dont work or exist on my forum when u go to the ACP And click onCrackertracker dont show me the icy tracker info the only think does show me is google web......
Sorry i dont speak English that good
Here's a minor issue:
Go into your profile.
Click on Preferences
In the left side nav bar, under Settings & Options
Clicking on Calendar gives you the Subforum Settings
Clicking on Subforums gives you the Calendar Settings
Also, the title for subforums is labeled Forums rather than Subforums.
doesn´t work
Any More Idea ???
Plz Help i Have some problem with tracker i can access ctrakcer on the ACP When i click on shows me google web was wrong with that ? i set CHMOD like the installeting said so!!! helpppp
Master09 wrote: [View Post]
doesn´t work
Any More Idea ???
You have got a byethost hosting, right?
If not, try re-uploading /ctraker/*.*
no i change to other host and the problem continue byethost,wmhot, and other
Subject: Icy Phoenix 1.1.10.25 RC 3
I have two problems with this version (Installation clean from scratch without prior version)
1) [img] page] [/ img] does not show the image of a remote URL, just shows me a link
2) I do not change the style default icy phoenix
P.D: Rc3 applied the patch but I still have these problems.
P.D2: I am behind a proxy in my localhost, but with the phpbb2 had no problems for the same link as you can see on the user jlijs of ***.portalbatch.com.ar but "ICY" if my localhost
doesn´t work
Any More Idea ???
I have Byethost hosting and have that problem man... what happend?
OdnaM wrote: [View Post]
doesn´t work
Any More Idea ???
Byethost doesn´t allow the crtaker scripts from being executed.
ok i try other host like wmhost.es.http://webmasterweb.info/. freehostia. and other 4 more hosting server and ctraker never work
Page 1 of 4
Generation Time: 0.7244s (PHP: 3% SQL: 97%)
