[SOLVED] Lang Change On Main Links ?
Subject: [SOLVED] Lang Change On Main Links ?
i have this little problem
when i m loged in i dont see that box for change language
langlogin
but when i logged off than i see that...
langlogoff
anybody know why ?? :oops:
Subject: Re: Lang Change On Main Links ?
Yes... Because the only way to change your language when you are logged in is via your Profile page. Those links only works for guests!!
Greets!
Thank you man :)
SOLVED
Subject: Re: [SOLVED] Lang Change On Main Links ?
Why is it that the styles works both not loged in and loged in?
Vuki wrote: [View Post]
we talking about language box ..not style Vuki
styles box work normaly
I know. But I would like for both to work normally.
Generation Time: 0.1004s (PHP: 17% SQL: 83%)
