BUG A Posible Problem In IP.com? =D
Subject: A Posible Problem In IP.com? =D
I runing in icyphoenix.com and the template is this :roll:
scr473b169ht4.th
Is at the 10:46 a.m. (-5 GTM) :v:
Subject: Re: A Posible Problem In IP.com? =D
It could be related with the /templates/images/ folder or the server/user cache.
Subject: Re: BUG - A Posible Problem In IP.com? =D
If it is only reporting that mistake was that I gave in icyphoenix.com :mricy:
Sometimes this happens with a busy server - the stylesheet doesn't get sent to the browser. Not sure why, perhaps under high load the server makes a consious choice not to send unneccessary bloat after creating the main content of the php scripts.
JHOSMAN wrote: [View Post]
scr473b169ht4.th
do you still have this problem?...
if so... i have had this problem ago too...
solution:
delete the .htaccess file in the template and/or mg_themes folder...
this worked for me..
greetz :)
It looks at the mine problem is not the problem I presenytó in IcyPhoenix.com :mrviolet:
Generation Time: 1.0385s (PHP: 2% SQL: 98%)
