Tpl - Php Programming Help Wanted
Inactive User
Subject: Tpl - Php Programming Help Wanted
I need to add a php var / string to statistics.tpl to include some markup to allow me to add different footers to Vista Crystal Styles without having to create a new theme-group just for the sake of three entries.
Existing Code:
<!-- BEGIN main_bottom -->
<div class="copyright" style="text-align:center;">{VERSION_INFO} &diams; {INSTALL_INFO} &diams; {VIEWED_INFO}</div>
<!-- END main_bottom -->
What I need to do:
#Start Conditions here#
</td>
</table>
#End conditions here#
The:
</td>
</table>
Has to be conditional on the fact that "if exists ../templates/vista/images/coppertone/" for it to be parsed. ?
And also be flexible to add other themes etc?
Else I'll have to make another theme group. :(
Can this be done? If so - How?? :?:
Subject: Re: Tpl - Php Programming Help Wanted
It is easy. Just paste in a spoiler vista.cfg file and I'll show you how.
Greets! :mricy:
Inactive User
Thanks Kas,
The conditions are very important that the path exists, else it will break the tables of other crystal themes. ;)
The themes affected are: army, cool, coppertone, pink and inferno. :(
Before ?>, add:
if ($color == 'crystal_coppertone')
$template->assign_block_vars('switch_crystal_coppertone', array());
If you also want to check for the folder existence you can use this code instead of the written upper:
if ($color == 'crystal_coppertone' && file_exists($current_template_images))
Greets!
Inactive User
8)
Thanks Kas, it looks like it should work - but it didn't :(
We had about the same problem with pa_*.tpl files not parsing vars from the theme.cfg file until MG modified pafiledb_common.php and added a pa.cfg.tpl file to vista templates.
If we have to go that way again, I'd rather just release them as either a group or all "Stand Alone" themes, because I'm beginning to think that one has to be a "Rocket Scientist Programmer" to apply all of the variations to one .cfg file without having to adjust the core.php files also to get these things to work independant of each other.
Themes really shouldn't be that difficult to make. So I may release all of the themes I have made / modified as stand-alone themes. And fix the problems with markup. :mryellow:
Lopalong wrote: [View Post]
I think the best way to release templates is in a pack so you don't have to upload big amounts of files each time you want to install a template... If the problem is PHP code, I think I can help you.
It should work on footer:
<!-- BEGIN switch_crystal_coppertone -->
</td>
</table>
<!-- END switch_crystal_coppertone -->
In PAFILEDB it should not work because there the template gets parsed in another way through another class...
Just try that code and clean cache.
Greets!
Inactive User
Thanks again, Kas.
But I did all that when I was testing it. ;)
I even removed one var: <!-- END switch_crystal_coppertone --> to see if it would generate an error, and it didn't. :(
The stat's footer also doesn't recognise {IMG_THR} etc, So unless I'm missing something, we're back to square one.
I'll just release them either as a group or stand-alone themes, as either way the problem will not be there anymore. :)
As to my thoughts on Group vs stand-alone themes, this is something I posted for Luca.
h**p://icythemes.com/ip/re-four-the...g-vp52.html#p52
Anyway, thanks Kas for the input but there were .php problems with pa_*.tpl files too before the core files were modified. And this time, that can be avoided. ;)
Well... pafiledb uses $pafiledb_template instead of $template... I thought you were going to use it in overall_footer...
Anyway thank you for your wonderful templates and good luck :mricy:
Inactive User
No, it's the stats footer that is / was the problem because I had to close and re-start tables elsewhere with the original Vista styles. And now with the different format for the latest additions, I needed to close off the statistics.tpl strictly with the "if exists" statement.
Doesn't matter now, there are quite a few of the "new" group that will be released here shortly as stand-alone themes - and there is a reason for that also.
Thanks again Kas for your input, but I'm glad now that I didn't go the way of adding them to the original Vista styles. ;)
Generation Time: 0.2032s (PHP: 12% SQL: 88%)
SQL queries: 9 - Debug Off - GZIP Enabled
