I opened up my forum this morning and discovered that someone has posted in my Administration and Announcement Forum as a guest. This is what was posted. It says that the Author is my user name and the date is 2003. What is this and how did this happen?
Author: davesco2_blair
Date: 08 Jul 2003 19:50
Category: Test Category 1
Type: Test Type 1
Comments: 0 Post your comments
Article Name: Test Article
Description: This is a test article for your KB
This is a test article for your Knowledge Base. This MOD is based on code written by wGEric <
> (Eric Faerber) - http://eric.best-1.biz/, now supervised by _Haplo <
> (Jon Ohlsson) - http://www.mx-system.com/
Be sure you add categories and article types in the ACP and also change the Configuration to your liking.
Have fun and enjoy your new Knowledge Base!
SOLVED Have I Been Hacked?
Subject: Re: Have I Been Hacked?
No you have not been hacked... this post is installed when you install the site to show you what it loks like... you can delete that post and add whatever you like....
You will also see a similar post in your forum about having installed Icy Phoenix which you also can remove...
hope that helps..
:mrgreen: :mrgreen:
hope that helps..
:mrgreen: :mrgreen:
Generation Time: 0.1243s (PHP: 13% SQL: 87%)
