SOLVED Having Trouble Installing
Subject: Having Trouble Installing
I have installed and upzipped and put the files on the right folder but it can't seem to find the install file. What has happened?
Subject: Re: Having Trouble Installing
Try uploading the /install folder again.
This happens to me all the time. :)
i will ask you question
what is name of your root folder (httpdocs , www , ) ?
what program you use to upload files of icyphoenix ?
rocko wrote: [View Post]
its not good !
how did you uploated ip_20080821_12027.zip in your cartoonz ?
see this picture
its not good !
see this picture
than open your file menager and upload files like in my picture
its not so complicated :wink:
look if you wish send me in PM your details .. and i will try upload ...then you will install
Generation Time: 0.1915s (PHP: 12% SQL: 88%)
