I uploaded phpbbbXS_058a_full and i run the instalation script , but when I fill in the fields with the corect details and when I click submit it apears a BLANK page ! So what should I do ?
PS. 2 Offtopic questions :)
1. How can I do so in posting_body.tpl in the left side should appear how many smiles I want ( for example 8 in a row and 8 in a column) (in a original phpBB) ?
2. Where I can see a list of MOD's that is installed on phpBB XS ?
Thanks in advance !
LE . Another OFFTOPIC question :)
How can I do so that the category or any bar to be formed within 3 images ( so if subSilver bar is formed with cellpic3.gif , I want to be on the left and on the right one image , for ex. cellpic3_left.gif and cellpic3_right.gif ) . How can I do that ? Exact Modifications please !
Blank Pages After Install
Subject: Re: BLANK PAGES ON INSTALL !
first do correct install, then we'll try to answer you to other questions
after click install you are connecting to database
it takes long time.wait
if it goes blank, maybe connection is too long or wrong and server execution time is out
in most it is 30sec.try to increase
do you create a database before install?
mods are in hacklist left hand navigation
No ... I had one database with SMF board but I've deleted the tables before installing phpBB XS ! So thats what I try to tell ou... I can't install it... After I click Install it goes blank without loading...
difus wrote: [View Post]
i didn't done anything to config.php... its exactly like in package !
My host is evonet.ro and the board is www.testarea.evonet.ro
you must chmod conf.php before installation
but you have one board
and you have only one sql database
don't understand
how help you :roll:
is it free hosting ?
don't understand
how help you :roll:
1º creat 1 Data Base
2º put the files xs058
( if not run install , please try remove everithing on file .htaccess )
try now. :LOL:
Aliniuz wrote: [View Post]
try now. :LOL:
nickjack had this problem :mrgreen:
it is servage rewrite module disabled
something that this in file .htaccess that it does not leave to install phpBBXS..
i remove and install ok....
I've CHMOD-ed 777 the config.php file and it still doesn't works !
I have a board and a MySQL database... What you don't udnerstand ... ?
Yes its a free hosting ... please help ...
LE : I renamed .htaacces file in a different name and it still gets blank when i Submit the Installation !
if you have one board
you can't have the second
really [I don't understand this languagr on your hosting]
do once more account at this free hosting and PM me how can I connect to it
I'll try to install to it , when I can said something to you :wink:
I see something wrong with your database
I'll try to export for you full fresh 058a database
be patient :wink:
be patient :wink:
delete or rename install and contrib directories
soon I PM your config.php
Same problem after doing what you told me to do ... help :cry:
Page 1 of 3
Generation Time: 0.0377s (PHP: 52% SQL: 48%)
