Bbcode Not Working! ._.
Subject: Bbcode Not Working! ._.
well, i installed the RC1 version and...
the selected bbcode not working (all popup bbcode? x_x)
agg
Internet explorer 7 show this errors:
line: 254
s_fc_help not defined
more errors:
s_img_insert
s_"all"_help
s_albumimg_insert
s_youtube_insert
(all not defined)
etc etc....
how i can fix this? >_<
and sorry for my bad english ._.
Subject: Re: Bbcode Not Working! ._.
Can you post a link to your site?
Did you tried with another browser?
If you didnt modify anyfile it should work, if dont, I think you should find out the files you modified and restore them.
wachowski wrote: [View Post]
site: www.anime-0x.com
i only modify a template file, (but if i use the default theme, i have the same error)
I tried the browsers IE7 and Chrome
and... i have another bug....
if I do click in the name of a user, i go to the forum index, not at the profile.... @_@
Man, if you have the same error with the default theme you're going to have the same because both are based on the same folder, maybe 'mg_themes', try to install anotherr theme that is based on other like i_themes or FK_nuke
Its a pitty cause your site really looks great
See ya
PS: ANother thing you can do is use the 'error console' (Herramientas>>consola de errores) in mozilla firefox. I used to fix my css problems in Phpbb3 using it.
i installed firefox and with "error console" see this:
sin_t_tulo_1
i try re-upload the js folder, but is the same errors...
solved, the problem is the vars... this vars are not defined in the "lang spanish" in the svn site for the spanish translation for icy phoenix RC1
ummm in:
http://svn.assembla.com/svn/icyphoe...e/lang_spanish/
exist the file "bbcode_mg.js" but this file "isn't read"
the content of this file need put on the lang_bbcb_mg.php
the language spanish in svn site is for other version of icy? ?_?
but well, i edited manually the lang_bbcb_mg.php and now work fine, thx for the support!
Ok, so you solved the problem? Thats great!
Here's is the resolution to your problem
http://www.icyphoenix.com/viewtopic...&highlight=vars
PS: I tought theres not an spanish translation for RC 1 yet. Did you get it from that link?
i understand that Lang spanish is for beta 2
you´ll have to wait for RC 1 Release.
another thing. since your using RC1, you wan´t be able to use I-themes. since that´s for 1.2.0.27c
Generation Time: 0.1726s (PHP: 10% SQL: 90%)
