Smtp Not Work!!!
Subject: Smtp Not Work!!!
Hello , i am not sure it is a bugs but Email Settings's smtp sure not work!!
I test in other phpBB that is work , but phpBBXS is not work!!!
Thank you
Subject: Re: Smtp Not Work!!!
Do you get any error messages?
Yes!!
Could not connect to smtp host : :
DEBUG MODE
Line : 113
File : smtp.php
Are you sure that SMTP setup is exactly like in your vanilla phpBB?
I never had any problems with the SMTP module unless the configuration was wrong. Judging by the error message, you've entered an incorrect SMTP server address.
Tom wrote: [View Post]
Yes, i am sure i am not wrong.
Check it out!
It's working for me on this site! :shock:
Can you try using other SMTP datas just to make sure that it's not an XS bug please?
ok!! i am try use other SMTP to test!!
I just see on my site that I can send email correctly from the email button, but doesn't work the "Email to a friend" function.
I get this error:
Ran into problems sending Mail. Response: 501 5.5.4 Invalid Address
DEBUG MODE
Line : 154
File : smtp.php
But the address is correct... I try many email address, but the error is the same. I use an SMTP server and not the Sendmail() PHP function.
Subject: Respuesta: Smtp Not Work!!!
Email friend on this site.
In this Web there is not problem of SMTP, not is a BUG to www.icyphoenix.com :oopsp:
I doubt it's a bug.
The error messages point to a problem with SMTP as Kuka said. You should check your SMTP server (deamon) config or let you provider check that.
I've checked smtp.php files included in XS... and is almost identical to the one of standard phpBB... so the problem shouldn't be in that file.
Can you please try replacing that file with the one of standard phpBB and let me know if the problem is solved?
Generation Time: 0.2566s (PHP: 13% SQL: 87%)
