Couldn't Obtain User/group Permissions
Subject: Couldn't Obtain User/group Permissions
Hello,
i have a problem with the group permissions. I can not change it. Then i will change it i become a error:
Couldn't obtain user/group permissions
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
SELECT * FROM bb_auth_access WHERE group_id = 3 AND forum_id =
Line : 281
File : admin_ug_auth.php
Info from my Version
Icy Phoenix Version: 1.3.0.53
Version von DB Maintenance: 1.3.6
Version von PHP: 5.2.10
Version von MySQL: 4.0.27-log
Can any one help me ? Sorry for my bad english, i come from Germany
Subject: Re: Couldn't Obtain User/group Permissions
it is a plain installation or an upgrade from phpBB 2?
It seems like the page cannot guess the forum id correctly.
Check both your auth and forums table for errors and run some DB Maintenance.
Hello,
i have upgrade from phbb 2. DB Maintenance i have run but the board have no problems found.
Also other users had this problem when upgrading from phpBB 2. :sad:
If you don't have too many forums and permissions I guess that the only solution is to empty the AUTH table.
Of course if you want to try, make a backup first.
Generation Time: 4.0361s (PHP: 0% SQL: 100%)
