Upgrade Problem.....
Subject: Upgrade Problem.....
Was upgrading from vanilla phpbb. Everything went fine, seemed to work, posted a message saying how everything would be updated when i got back from my lectures (2 hrs i was away for).
Came back. Logged on, went to go to my forum to start the work, and i get this message...
Critical Error!
message_die() was called multiple times.
Error #1
Line : 132
File : /usr/local/psa/home/vhosts/napuk.co.uk/subdomains/community/httpdocs/includes/functions_jr_admin.php
SQL : SELECT * FROM phpbb_jr_admin_users WHERE user_id =
Error #2
Line : 132
Any help on the problem would be greatfully appreciated.
Subject: Re: Upgrade Problem.....
OK, after my forum disapeared for a bit, managed to get it back again with the error message.
Tried to do a search for it but all i get is a CT security message telling me there is a worm or something, so i cant search for it.
Any help would be greatfully appreciated :)
go to sql database [phpmyadmin] select all and do repair
you have a syntax error
if needs do twice
Nope still hasnt done anything, and ive ran it 3 times.
if you'll go to nothing you can PM me full access to your ftp and phpmyadmin :wink:
Ive figured out that it only occurs when people are logged out of the forum.
As i found out, as i tested when i logged out and can now not log back in :LOL: Stupid me!
Right, im going to have one last go at upgrading, and if this doesnt work, ill start the tedious task of installing mods on a fresh install.
No, it hasnt worked, you may close this thread, im going to design my own forum, and add own mods.
Sorry! :)
Right, because im the stubborn type and really wanted to use this system, ive kept going and going and going, and finally got it working, just a little message showing on portal that says the following
Warning: Division by zero in /usr/local/psa/home/vhosts/napuk.co.uk/subdomains/community/httpdocs/includes/functions.php on line 1016
Warning: Division by zero in /usr/local/psa/home/vhosts/napuk.co.uk/subdomains/community/httpdocs/includes/functions.php on line 1023
:mrviolet:
Any ideas?! :mrblue:
napukjon wrote: [View Post]
:mrviolet:
Poste here those lines...
Generation Time: 0.1734s (PHP: 11% SQL: 89%)
