SOLVED Image Amount In A Post Icy Phoenix
Subject: Image Amount In A Post Icy Phoenix
Hi guys what ups? i have a problem with i don` can`t find if there a option for image amount in a post i have search this but i can“t find please help me
The problem is that i make a post but they are much image i so i whant put more amount imagen in the post is that possibled?
Greetings From Chile :mrgreen:
Subject: Re: Image Amount In A Post Icy Phoenix
Dbz_Warrior wrote: [View Post]
If you mean that if there is a limit to the number of images that you can include in a post the answer is no, otherwise try to explain better what you want to know :wink:
Oh thanks you man that was i question
Generation Time: 0.07s (PHP: 23% SQL: 77%)
