SOLVED The Following SQL Have Not Been Executed:
Subject: The Following SQL Have Not Been Executed:
Icy Phoenix - Update in progress
The following SQL have not been executed:
Spoiler: [ Hide ]
* CREATE TABLE `ip_tickets_cat` ( ticket_cat_id MEDIUMINT(8) UNSIGNED NOT NULL AUTO_INCREMENT, ticket_cat_title VARCHAR(255) NOT NULL DEFAULT '', ticket_cat_des TEXT NOT NULL, ticket_cat_emails TEXT NOT NULL, PRIMARY KEY (ticket_cat_id) )
+++ Error: Table 'ip_tickets_cat' already exists
* INSERT INTO ip_config VALUES ('ip_version', '1.3.0.53b')
+++ Error: Duplicate entry 'ip_version' for key 'PRIMARY'
how fix this ?
Subject: Re: The Following SQL Have Not Been Executed:
no need to fix this.
the message tells you, that the data exists.
should work whithout problems
THX .. :wink:
Generation Time: 0.0849s (PHP: 19% SQL: 81%)
