Hello.
I've uploaded the style "milky_way_red" to the template folder, but when I go to the ACP to install the style the option to install the style is not on the list.
I've been searching through this forum and I can't seem to find a solution to this problem. Please help.
SOLVED Cannot Install Milky_way_red
Subject: Re: Cannot Install Milky_way_red
Hi dooke,
Can you confirm you are using IcyPhoenix and NOT phpbb3?
EDIT: .. you may simply be installing an Icytheme on phpbb or the other way arround
I can 100% confirm that I'm using IP, heres a link for my site: h**p://dooke.byethost5.com/forum/
Joshua203 wrote: [View Post]
OK this is why I said "or the other way arround" :mryellow:
Opening you milky directory, this is what I noticed in a .cfg file:
which tells me you have a phpbb3 style installed :wink:
for Milkyway Red IcyPhoenix you need >>THIS<<
You're welcome, I'll mark this "solved" for you, which you can do to ...next time :mryellow:
Generation Time: 0.11s (PHP: 16% SQL: 84%)
