Hi again... site is up and running using v1.3.0.53b
all is working fine with the three installed templates..ice,frozen and MG autumn but I am trying to install black pearl.
I have installed the files in icyphoenix/templates/icy_phoenix/images where the other templates appear to be, folders and files look similar so I'm confident I have it right, but I cannot bring it up in the <install styles>
any suggestions would be appreciated, as its the only thing so far that I just cannot get going?
thank you in advance
SOLVED Recognising An New Template
Subject: Re: Recognising An New Template
Please try "icyphoenix/templates/pearl" Zag :wink: you may be pleasantly suprised :mrorange:
Thank you..that solved almost all my problems. clearly I put the files into the wrong directory.
Another silly question however, I am getting a lot of missing icons <little x boxes> in internet explorer, but all the icons are there in Firefox..this is more an IE problem I'm thinking but any suggestions?
thanks for your assistance,
ZAG
ZAG
That should not happen not even in IE :LOL:
Do you have a link so any of us can take a closer look?
PS have you tried clearing IE's cache?
I installed another template and its working fine, so I'm guessing that I tried to upload the original so many times I probably corrupted it.
thanks for your assistance... site looks great now
ZAG (will mark as fixed)
You're welcome Zag,
My guess about the missing images is that they still are at the directory of your initial install (mixed among the pics that should really be there, I hope you did not overwrite any of the originals)
I guess you couldn't find the title edit feature (should be bottom right!) so I marked it SOLVED for you ;)
Have a GREAT day,
...Joshua203
Have a GREAT day,
...Joshua203
Generation Time: 0.0633s (PHP: 27% SQL: 73%)
