Won't install because of a fatal error.
Fatal error: Call-time pass-by-reference has been removed in F:\xampp\htdocs\forum\includes\album_mod\album_functions.php on line 1035
line 1035 album_build_column_vars(&$result, $data, $page_params);
The & appears to be the problem.
[BUG] Icy Phoenix 2.0 Fatal Error: Call-time Pass-by-reference Has Been Removed
Subject: Re: [BUG] Icy Phoenix 2.0 Fatal Error: Call-time Pass-by-reference Has Been Removed
I´ve installed on xampp without a problem
xampp version 1.7.4
xampp version 1.7.4
XAMPP like everything else (Including Icy Phoenix) deprecates some functions between versions, maybe you could try the latest version and see what happens?
Edit:
Reference: http://stackoverflow.com/questions/...y-fix-available
My Setup:
XAMPP Full version 1.8.0 installed on USB Stick. Windows 7 - 64bit :roll:
###### ApacheFriends XAMPP Version 1.8.0 ######
+ Apache 2.4.2
+ MySQL 5.5.25a (Community Server)
+ PHP 5.4.4 (VC9 X86 32bit thread safe) + PEAR
+ XAMPP Control Panel Version 3.0.12 by hackattack142 (Great Thanks!!))
Vgl.: http://www.apachefriends.org/f/viewtopic.php?f=16&t=46743
+ phpMyAdmin 3.5.2
+ OpenSSL 1.0.1c
+ ADOdb 5.15
+ XAMPP Security
+ Mercury Mail Transport System v4.62 (not included in the portable version)
+ FileZilla FTP Server 0.9.41 (not included in the portable version)
+ Webalizer 2.23-04 (not included in the portable version)
+ Strawberry Perl 5.16.0.1 Portable
+ Tomcat 7.0.28 (not included in the portable version)
+ Old XAMPP Control Panel Version 2.5 von www.nat32.com (deprecated)
+ XAMPP mailToDisk 1.0 (write sendet emails via PHP on local disk in <xampp>\mailoutput. Is activated in the php.ini as mail default.)
Edit:
My Setup:
+ Apache 2.4.2
+ phpMyAdmin 3.5.2
+ OpenSSL 1.0.1c
+ ADOdb 5.15
+ XAMPP Security
Hey,
I made a little fix but I forgot to put it here. It's because call-time pass-by-reference has been removed with php5.4
The fix is really simple, you just have to remove that "&"
https://github.com/Nami-Doc/icy_pho...bc35900aebfa60c
since the & is in the actual function's definition.
The & has to be removed.
I will remove it in repository.
I'll release a small patch very soon.
The joys of being a programmer - - One starts something and by the time it's finished someone else has deprecated some, or a lot of it. :mryellow:
But I had already removed it so that I could finish the installation.
Generation Time: 0.1619s (PHP: 11% SQL: 89%)
