Cannot Get 'Signature' To Work At All.
Subject: Cannot Get 'Signature' To Work At All.
Under 'Profile' > 'Settings' > 'Preferences' > 'Attach my signature to my prior posts' click in box - Submit, page refreashes, but nothing appears to happen, I would have thought the tick would have remained on, but no.
Under 'Profile' > 'Personal Profile' > 'Signature' when I clicked on
h**p://localhost/icyphoenix/profile.php?mode=signature
This came up in the browser window
Content Encoding Error
The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression.
Please contact the website owners to inform them of this problem.
Signature does not work at all, is there something missing? or a possible bug?
I have searched the forum and cannot find this problem and am at a complete loss with this one.
I did download the 'dynamic_signature' zip file in the hopes this may help cure the problem, but no details of where to put the files are included.
Installed this two weeks ago, latest version July 2014
Wampserver: 2.5
PHP Version: 5.5.12
Apache: 2.4.9
MySQL: 5.6.17
Current as of August 2014
Version of Icy Phoenix: 2.0.0.86
Editor I Use: UltraEdit32
Browser: Firefox 31.0
Windows: 8.1
Subject: Re: Cannot Get 'Signature' To Work At All.
Where did you get this dynamic_signature.zip from?
And a URL to the download would be appreciated.
If you get a "content encoding error", you should try to disable gzip compression in your ACP and go back to that page ... :(
Apart from Informpro suggestion, you can also try to scan the log of your server to check if there is some extra problem.
Generation Time: 0.6454s (PHP: 3% SQL: 97%)
