Post Rules Empty Page
Attemping to edit the Rules file from ACP, then clicking "Home" button, instead of the "submit" one, I get now:
[list]a blank page selecting Rules link in the Home page;
the ACP menu completely empty.[/list]
I'm working on a local installation, italian language.
modularpathSend private message
Post Re: Rules Empty Page
same problem on my site
and at the moment i have no solution for this... anyone else?
Play Games at GamesCampus!
I have the same problem!
Version in use? I don't have any problem with 1.0.10.10... you can view the rules settings on ACP?
andrea75 wrote: [View Post]
I use 1.0.10.10, but the English language file is good but when i switch to Dutch language file it doesn't work correctly.
And i have a problem with use the admin tools for this files. It works not correctly. The tools can't find the blocks but it does exist in the files.
lang_rules.rar
Description: The Dutch file that doesn't work @ rules page. Is there a error in this file?
Filename: lang_rules.rar
Filesize: 3.06 KB
Downloaded: 143 Time(s)
Edited by brandsrus, Thu 15 Mar, 2007 21:09: file added
OK...  now I remeber what I do to fix it
OPEN your lang_rules.php file (not english language, but only others)
$rules[]
$faq[]
You have to change all the " carachters with ' too....
Merge the file with english language and ceck it better...
Thanks, it works andrea75    0056  :10k_0017:
brandsrus wrote: [View Post]
Good!  0050 Happy for this!
wooow,
thanks andrea for the hint... now it works for me too.
The error wasn't that one...
I think you didn't remove the old file in ACP.
Anyway there was another bug... which I should have definitely fixed... let's see if in RC version everything is working fine.
Yes, there is an old file in ACP too, but it's not enough: if you delete the old file you will have no errors in ACP, but you still have the blank page on rules.php, because only english lang file was updated with the $faq[] tag instead $rules[]. I don't know if this a good solution, but it works So I've decided to post it anyway.
