Post Error Upgrading From XS0.58 To Icy
I did a backup of all my forum and installed a clone forum to test before official upgrade... and I got many errors.
Then, I installed a vanilla XS and just after having completed the installation I tryed the upgrade to Icy.
I got this strange alternance of errors, the same I had with my forum...
After having changed the files I got
Critical Error
Could not open ca_aphrodite template config file
Any idea of what the problem could be?
Remember that all has been done on a fresh installed XS 0.58b...
PS: I attached a .zip with an html page of the results in case you need it (greens and reds are more comfortable to read ). Don't worry about the CHMOD, I tryed to chmod all correctly but errors appear the same
results.zip
Filename: results.zip
Filesize: 9.44 KB
Downloaded: 222 Time(s)
Post Re: Error Upgrading From XS0.58 To Icy
I did more tests but the result is always the same...
The errors on update are normal.
About template missing: try to upload def_*.php file from installcontribcleanincludes directory and let me know.
andrea75 wrote: [View Post]
Thanks for help Andrea,
Now I got
Critical Error
Could not locate valid language pack
Vortex wrote: [View Post]
Now I got
Critical Error
Solved, I had italian language saved in my profile, I changed it from phpmyadmin
But now I still got
Critical Error
I uploaded clean def_ files...
Now I got
Critical Error
But now I still got
Critical Error
If you can, change the default theme from phpmyadmin, with ID of an existing template (Icyphoenix or MG_Autumn). Other way is install the ca_aphrodite theme... you can find it on downloads section.
Now I got
[quote]Critical Error
Could not locate valid language pack[/quote]
But now I still got
Critical Error
- How can I install a new theme if I can't access the ACP? I don't know how to install it manually.
- In config and users (to my user) tables I set the id of the theme to "0" (which should be Icy) but the error is the same... I'd like to know where does it find "ca_aphrodite"...
Hi! I had the same problem!!
Upload ca_aphrodite directory from XS to your new forum, so you can enter with too many errors. Enter in ACP, and install the new theme (icy, or autumn), after that put by default, for all users one of the new themes .
My 2 IP Forums:
Try solution of tiolalu.
You have only to upload the ca_aphrodite folder. The theme was just installed.
Ok, thanks for help
I succeeded to install Icy theme after accessing the ACP with ca_aphrodite. When selecting Icy theme I got
General Error
CBACK CrackerTracker couldn't run the database operation correctly.
Is it me or the update process should be revisited?
I think you didn't upgrade your forum properly... I did several tests and all upgrades have been performed correctly.
If you have a backup, try to roll back to it and start again following these instructions step by step.
Readme
Mighty Gorgon, why backup .htaccess if you don't use it after .
My 2 IP Forums:
Mighty I tryed even upgrading a vanilla XS...
Do you still have problems with this?
Can you please check that all the needed files are there?
Are you sure you are choosing the correct option from the update script?
The cache has been cleaned after the upgrade?
A new installation is working fine?
I tried again and doesn't work. Nor for my actual site nor for a vanilla XS0.58 installation.
Done, and all seems to be right...
Yes, I am... I chose "Upgrade from XS 0.58" and I got many errors ALL updating the config table... you can see it from the file I attached.
I tried two times upgrading from a vanilla XS installation and I got the same errors I got upgrading my actual site... ALL errors are related to the upgrade of the config table... I am not expert so sorry if I dare ask this, but are you sure the upgrade file doesn't have any bug or something?
Yes, I cleared it from FTP because I had problems with the template.
I tried again both a new installation (of XS, then upgrading) and upgrading from my site. Always the same errors.
I proceeded as the other guys suggested me as you can see in this topic... now I succeded to login and access the ACP, after having uploaded the aphrodite XS theme, and changed it from phpMyAdmin... when I got to ACP and try to change the template to Icy I got this error:
Now I am very busy with examinations... When I got a little time I will start from zero, cloning again my site and upgrading it to the new RC3
Post new topic  This topic is locked: you cannot edit posts or make replies.  Page 1 of 2
