Post Accsess Denied - Personal Galleries
Hi all, just a quick question really: when I try to open personal galleries I get an accsess denied message, I have searched these boards and found that others have had the same problem, but cant find a solution I am using build 101111_rc is this a known bug that cannot be fixed or is there a solution that I cannot find? I have set all permissions correct as far as I know and neither users or admin can create a personal gallery and just get this meesage.
Can anyone help?
Regards
K_S
PS site is not live yet, but am willing to PM details and any permisions to a mod to check it out
K_SSend private message
Post Re: Accsess Denied - Personal Galleries
hi
try this on post #3
http://www.icyphoenix.com/viewtopic.php?t=1659
Pepi
pepiSend private messageVisit poster's website
Below is from post 3 as suggested....
Hi
I have switched on this bit of code
Code: [Download] [Show]
// Old AUTH Check for PG
$auth_data = album_permissions($album_user_id, $cat_id, ALBUM_AUTH_ALL, $thiscat);
and tuned off this bit...
// New AUTH check for PG
//$auth_data = album_get_auth_data(album_get_personal_root_id($album_user_id));
Now my personal galleries are working..I can assume this is not the way it should be so has anyone got a better solution at all...
FYI this is a fresh install of the recent icy phoenix package on php 5 and mysql 5...
Thanks ..
Sorry but what is meant by switched on and turned off?, pretty new to this stuff but can edit php file spretty succsessfully
Thanks again for your help.
K_S
Never Mind I understand now and have changed it .
Now working , I think this should be highlighted as a fix somewhere sticky as it was harder to find than it should be .
Regards,
K_S
Hi
To switch of and turn on code as I aid is basically to addor remove these 2 slashes
so I removed those 2 slashes from the first part of the code to turn the code on and addedd them to the second bit to turn that bit of code off....
I hope that helps
Yes thanks for that I finally worked it out and it all works fine now
Thanks for your help
K_S
No problem
Happy to help...
Ok guys another one for you
didnt start another topic thought it would be easier to add here.
Is it possible to create a pro user group and set an individual upload quota for each users personal gallery and add to the quota as they go?
does that make sense?
In other words say I had prouser 1 and prouser 2 I would like user 1 to have a personal gallery quota limit of 100 and user 2 to to have a limit of 60.
then at a later time I would like to increase user 2's limit to 100 is this possible?
Thank in advance.
K_S
