Post Errors When Opening The ACP
cpbugsn8.th
Warning: set_time_limit() has been disabled for security reasons in /home/www/excathedra.awardspace.com/forum/adm/admin_yahoo_search.php on line 28
Warning: Cannot modify header information - headers already sent by (output started at /home/www/excathedra.awardspace.com/forum/adm/admin_yahoo_search.php:28) in /home/www/excathedra.awardspace.com/forum/adm/page_header_admin.php on line 184
Warning: Cannot modify header information - headers already sent by (output started at /home/www/excathedra.awardspace.com/forum/adm/admin_yahoo_search.php:28) in /home/www/excathedra.awardspace.com/forum/adm/page_header_admin.php on line 186
Warning: Cannot modify header information - headers already sent by (output started at /home/www/excathedra.awardspace.com/forum/adm/admin_yahoo_search.php:28) in /home/www/excathedra.awardspace.com/forum/adm/page_header_admin.php on line 187
Any idea of how to fix this, please?
ApockalyptikSend private message
Post Re: Errors When Opening The ACP
Hi, Apockalyptik
It seems you have problem with set_time_limit() php function, or php safe mode is enabled. Go to ACP->Info->PHP Info and look for the line safe_mode. It should be off. If it's on, you should change it in php.ini file. If you don't have access to PHP configuration on your server, try asking your host if safe_mode can be disabled.
I don't know is this going to help, but you could try to do following:
OPEN /adm/admin_yahoo_search.php
REMOVE
if ( ! strtolower(@ini_get('safe_mode')) )
    set_time_limit(180);
Try it and post here what happened.
Omarska online
omarskaSend private messageVisit poster's website
