Post Change User Permissions
Hi all.
I've a problem with ACP.
I need to change lot of permissions of a user.
I go at ACP/Users/permissions/"select the nick of the user"/advenced mode.
Now,in this panel i can only change 2 permissions for the user: "is/isn't a moderator" and  "News off/on".
How can i change the other permissions? (download file,create pool,vote etc..)
Hip_TSend private message
Post Re: Change User Permissions
Inside Permissions in forums administration
But if i want to change the permission of a single user?Can i do it?
there aren't single permissions :S you can give group permissinos
So, if i create a new group and insert this user in it.After,how can i change the permission for this group?
Go to Groups -> Permissions
But if  i try with "User" group i can change only 2 options ("is/isn't a moderator" and  "News off/on". )
You have to set download file,create pool,vote etc.. permissions to private
after that, you have to edit group permissions and set it as u like
I've try to set the permission in private but i see only whis option,the same problem appera if i try to change permission to a group.
See the img here
but inside forum permissions you have to set all that u want to private, not only news
that's why u can't set them fine
Ok,now i've think.
Thanks for the help and for the patience.
No problem
