Post ACP Update Message?!
Hi Folks,
I have installed the 1.1.10.25 RC3. And when i enter my ACP the message on the top says: ": Updates are available for your version of Icy Phoenix, please visit Icy Phoenix to obtain the latest version.
I don't really understand what i have to do to because i think i have downloaded and installed the RC3 board. What else can be done, what i can check...
I thought RC3 is the last available version...
Thanks for your support in advance.
HuorSend private messageVisit poster's website
Post Re: ACP Update Message?!
Here: http://www.icyphoenix.com/viewtopic.php?f=1&t=3417
Mighty Gorgon" wrote:
2008/01/16: I have attached this post a patch to fix some bugs into RC3... all you have to do is replace all files.
I don't know, maybe when aplying the patch everything goes fine
how can i upgrade from ip 1.1.10.25 to RC3 really i don't know what i do ...
i have download the ip_20080208_patch_rc3 and upload it to my forum, now what i do to run upgrade...
mafridiSend private message
mafridi wrote: [View Post]
You don“t need to run any SQL queries. Just owerwrite files.
Huor wrote: [View Post]
Hi Folks,
RC are not final release... so you will have that message until RC3 will go final.
Thanks m8ty
easy answer and easy to understand... Thanks for your effort!
BTW want to mention that i more and more get familiar with icy phoenix and it has much features i can use now. really great work!!!
