christmanrd
 Icy Phoenix 1.3.0.53 - Webpage Error Details
In the "Status Bar" on IE there is a warning of "Done, but with errors on page"
Here is the error details. How do I find and fix this?
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1) ; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Tue, 18 Aug 2009 19:15:03 UTC
Message: Syntax error
Line: 555
Char: 13
Code: 0
URI: http://blaircountyteaparty.org/index.php
Thanks,
Dave
____________ Another Pro Bono
Version of Icy Phoenix: 1.3.0.53a
Version of PHP: 5.2.9
Version of MySQL: 5.0.81-community-log
Board started: 2009/07/18 - 11:50
Registered Users: 123 as of 17 Sep 09
#1 Tue 18 Aug, 2009 21:18 |
Inactive User
 Re: Icy Phoenix 1.3.0.53 - Webpage Error Details
It's probably correct Dave, but I wouldn't worry about changing it. MG would need to modify the offending script that has empty tables.
Line 555:
<table class="forumline-no2" width="100%" cellspacing="0" cellpadding="2" border="0">
<td width="8" align="left"><img src="language/lang_english/flag.png" alt="English" /></td>
<td class="genmed" align="left"><a href="changelang.php?l=english">English</a>
</td>
</table>
No that's not the problem, the problem is here, which is actually Line 505 (Or I think it was) and it's seeing this twice: <!-- <!-- ? h**p://***.icyphoenix.com/viewtopic.php?p=43156#p43156
#2 Wed 19 Aug, 2009 09:28 |
Try Lopalong suggestion and let me know if the error disappear.
#3 Wed 19 Aug, 2009 11:23 |
Inactive User
I did try this with a View Source version of the html and the errors disappeared.
tmp = 'users_links';
if(GetCookie(tmp) == '2')
ShowHide('users_links', 'users_links2', 'users_links');
</script>
#4 Wed 19 Aug, 2009 11:43 |
christmanrd
</script>
That's great. One question. Am I to find this in the index.php? I looked but I do not see anything that resembles what you submitted. It looks like it might be in the nav_quick_links.tpl
#5 Wed 19 Aug, 2009 16:31 |
spydie
this seems to be in overall header or in page_header.php
Edit:
No it is“nt. Been wrong hmpf.
____________ Out of Order
#6 Wed 19 Aug, 2009 16:44 |
DWho
no it is in...nav_quick_links.tpl i had already pmed christmanrd regarding errors.. in this file... as someone had a go at hiding links...
I thought he had sorted it out but never replied...
oh well
#7 Wed 19 Aug, 2009 21:21 |
christmanrd
The nav_quick_links.tpl that is on line is the .tpl that I thought you sent back to me DWho.
The reason I had a go at it was because, I could not turn of items in my Dynamic Menu through the CMS. So, I tried to do it myself.
In the PM you stated, Quote: copy this code into your nav_quick_links tpl file it will sort out the problems you are having
Not fully understanding what it was you were telling me to do but, comfortable then and now with the fact that you know what you were doing. So, I copied the code and used it to replace the code that was in my nav_quick_links.tpl and uploaded it to the server.
What is being display is the code that you sent me.
I still would like to know why I can not do this in the CMS. I thought it could be done that way.
Hope I stated it correctly.
Thanks,
#8 Wed 19 Aug, 2009 21:43 |
DWho
if you had replied to my PM i would have known there was a problem still...
anyway here is the full code with the error fixed..
<!-- IF SWITCH_CMS_GLOBAL_BLOCKS -->
tmp = 'quick_links';
ShowHide('quick_links', 'quick_links2', 'quick_links');
setWidth('var_width', 16);
//setWidth('full_width', '100%');
</script>
<!-- ENDIF -->
<form name="ChangeThemeLang" method="post" action="{REQUEST_URI}">
{IMG_THL}{IMG_THC}
<img class="max-min-right" style="{SHOW_HIDE_PADDING}" src="{IMG_MINIMISE}" onclick="ShowHide('quick_links', 'quick_links2', 'quick_links'); setWidth('var_width', 16); setWidth('full_width', '100%');" alt="{L_HIDE}" />
<!-- ENDIF -->
<span class="forumlink">{L_QUICK_LINKS}</span>{IMG_THR}<table class="forumlinenb" width="100%" cellspacing="0" cellpadding="0">
<!-- IF NAV_MENU_ADS_TOP -->
<th style="cursor: pointer;" align="left">
<img src="{IMG_NAV_MENU_SPONSOR}" alt="{L_SPONSORS_LINKS}" title="{L_SPONSORS_LINKS}" />
<a href="#" onclick="return false;" title="{L_SPONSORS_LINKS}" class="nav-menu-link"><b>{L_SPONSORS_LINKS}</b></a>
</th>
<tr><td class="row1">{NAV_MENU_ADS_TOP}</td></tr>
<!-- ENDIF -->
<th style="cursor: pointer;" align="left" onclick="ShowHide('main_links', 'main_links2', 'main_links');">
<img src="{IMG_NAV_MENU_APPLICATION}" alt="{L_MAIN_LINKS}" title="{L_MAIN_LINKS}" />
<a href="#" onclick="return false;" title="{L_MAIN_LINKS}" class="nav-menu-link"><b>{L_MAIN_LINKS}</b></a>
</th>
<td class="row5">
<div id="main_links2" class="nav-menu">
<!-- IF S_ADMIN -->
<td align="left" width="8">{IMG_NAV_MENU_SEP}</td>
<td class="genmed" align="left">{U_ACP}</td>
<td class="genmed" align="left"><a href="{U_CMS}">{L_CMS}</a></td>
<!-- ENDIF -->
<td class="genmed" align="left"><a href="{U_PORTAL}">{L_HOME}</a></td>
<!-- IF S_LOGGED_IN -->
<td width="8" align="left">{IMG_NAV_MENU_SEP}</td>
<td class="genmed" align="left"><a href="{U_PROFILE}">{L_CPL_NAV}</a></td>
<!-- ENDIF -->
<td class="genmed" align="left"><a href="{U_INDEX}">{L_FORUM}</a></td>
<td class="genmed" align="left"><a href="{U_BOARDRULES}">{L_BOARDRULES}</a></td>
<td class="genmed" align="left"><a href="{U_FAQ}">{L_FAQ}</a></td>
<td class="genmed" align="left"><a href="{U_SEARCH}">{L_SEARCH}</a></td>
<td class="genmed" align="left"><a href="{U_SITEMAP}">{L_SITEMAP}</a></td>
<td class="genmed" align="left"><a href="{U_ALBUM}">{L_ALBUM}</a></td>
<td class="genmed" align="left"><a href="{U_CALENDAR}">{L_CALENDAR}</a></td>
<td class="genmed" align="left"><a href="{U_DOWNLOADS_NAV}">{L_DOWNLOADS}</a></td>
<td class="genmed" align="left"><a href="{U_BOOKMARKS}">{L_BOOKMARKS}</a></td>
<td class="genmed" align="left"><a href="{U_DRAFTS}">{L_DRAFTS}</a></td>
<td class="genmed" align="left"><a href="{U_UPLOADED_IMAGES}">{L_UPLOADED_IMAGES}</a></td>
<td class="genmed" align="left"><a href="#" onclick="window.open('chatbox_mod/chatbox.php', '_chatbox', 'resizable=yes,scrollbars=yes,width=600,height=460'); return false;">Chat</a></td>
<!-- ENDIF -->
<td class="genmed" align="left"><a href="{U_AJAX_SHOUTBOX}">{L_AJAX_SHOUTBOX}</a></td>
<td class="genmed" align="left"><a href="{U_LINKS}">{L_LINKS}</a></td>
<td class="genmed" align="left"><a href="{U_KB}">{L_KB}</a></td>
<td class="genmed" align="left"><a href="{U_CONTACT_US}">{L_CONTACT_US}</a></td>
<td class="genmed" align="left"><a href="{U_SUDOKU}">{L_SUDOKU}</a></td>
<!-- ENDIF -->
</table>
<div id="main_links" class="js-sh-box">
tmp = 'main_links';
</script>
</td>
<th style="cursor: pointer;" align="left" onclick="ShowHide('news2_links', 'news2_links2', 'news2_links');">
<img src="{IMG_NAV_MENU_NEWSPAPER}" alt="{L_NEWS_LINKS}" title="{L_NEWS_LINKS}" />
<a href="#" onclick="return false;" title="{L_NEWS_LINKS}" class="nav-menu-link"><b>{L_NEWS_LINKS}</b></a>
</th>
<td class="row5">
<div id="news2_links2" class="nav-menu">
<td class="genmed" align="left"><a href="{U_PORTAL_NEWS_CAT}" title="{L_NEWS_CAT}">{L_CATEGORIES}</a></td>
<td class="genmed" align="left"><a href="{U_PORTAL_NEWS_ARC}" title="{L_NEWS_ARC}">{L_ARCHIVES}</a></td>
<td class="genmed" align="left"><a href="{U_SEARCH_NEW}">{L_NEW3}</a></td>
<!-- ENDIF -->
<!-- BEGIN switch_upi2db_on -->
<td class="genmed" align="left"><a href="{U_DISPLAY_U}" title="{L_DISPLAY_U_S}">{L_DISPLAY_UNREAD_S}</a></td>
<td class="genmed" align="left"><a href="{U_DISPLAY_M}" title="{L_DISPLAY_M_S}">{L_DISPLAY_MARKED_S}</a></td>
<td class="genmed" align="left"><a href="{U_DISPLAY_P}" title="{L_DISPLAY_P_S}">{L_DISPLAY_PERMANENT_S}</a></td>
<!-- END switch_upi2db_on -->
<!-- BEGIN switch_show_digests -->
<td class="genmed" align="left"><a href="{U_DIGESTS}">{L_DIGESTS}</a></td>
<!-- END switch_show_digests -->
</table>
<div id="news2_links" class="js-sh-box">
tmp = 'news2_links';
</script>
</td>
<th style="cursor: pointer;" align="left" onclick="ShowHide('info_links', 'info_links2', 'info_links');">
<img src="{IMG_NAV_MENU_INFORMATION}" alt="{L_INFO_LINKS}" title="{L_INFO_LINKS}" />
<a href="#" onclick="return false;" title="{L_INFO_LINKS}" class="nav-menu-link"><b>{L_INFO_LINKS}</b></a>
</th>
<td class="row5">
<div id="info_links2" class="nav-menu">
<td class="genmed" align="left"><a href="{U_HACKS_LIST}">{L_HACKS_LIST}</a></td>
<td class="genmed" align="left"><a href="{U_REFERRERS}">{L_REFERRERS}</a></td>
<td class="genmed" align="left"><a href="{U_VIEWONLINE}">{L_WHO_IS_ONLINE}</a></td>
<td class="genmed" align="left"><a href="{U_STATISTICS}">{L_STATISTICS}</a></td>
<td class="genmed" align="left"><a href="{U_DELETE_COOKIES}">{L_DELETE_COOKIES}</a></td>
</table>
<div id="info_links" class="js-sh-box">
tmp = 'info_links';
</script>
</td>
<th style="cursor: pointer;" align="left" onclick="ShowHide('users_links', 'users_links2', 'users_links');">
<img src="{IMG_NAV_MENU_GROUP}" alt="{L_USERS_LINKS}" title="{L_USERS_LINKS}" />
<a href="#" onclick="return false;" title="{L_USERS_LINKS}" class="nav-menu-link"><b>{L_USERS_LINKS}</b></a>
</th>
<td class="row5">
<div id="users_links2" class="nav-menu">
<td class="genmed" align="left"><a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a></td>
<td class="genmed" align="left"><a href="{U_GROUP_CP}">{L_GROUP_CP}</a></td>
<td class="genmed" align="left"><a href="{U_RANKS}">{L_RANKS}</a></td>
<td class="genmed" align="left"><a href="{U_STAFF}">{L_STAFF}</a></td>
</table>
<div id="users_links" class="js-sh-box">
</script>
</td>
<!-- BEGIN style_select_on -->
<!-- <tr>
<th style="cursor: pointer;" align="left" onclick="ShowHide('style_select', 'style_select2', 'style_select');">
<img src="{IMG_NAV_MENU_PALETTE}" alt="{L_SELECT_STYLE}" title="{L_SELECT_STYLE}" />
<a href="#" onclick="return false;" title="{L_SELECT_STYLE}" class="nav-menu-link"><b>{L_SELECT_STYLE}</b></a>
</th>
<td class="row5">
<div id="style_select2" class="nav-menu">
<td class="genmed" align="center">{STYLE_SELECT_H}</td>
</table>
<div id="style_select" class="js-sh-box">
tmp = 'style_select';
</script>
</td>
<!-- END style_select_on -->
<!-- BEGIN lang_select_on -->
<th style="cursor: pointer;" align="left" onclick="ShowHide('lang_select', 'lang_select2', 'lang_select');">
<img src="{IMG_NAV_MENU_WORLD}" alt="{L_SELECT_LANG}" title="{L_SELECT_LANG}" />
<a href="#" onclick="return false;" title="{L_SELECT_LANG}" class="nav-menu-link"><b>{L_SELECT_LANG}</b></a>
</th>
<td class="row5">
<div id="lang_select2" class="nav-menu">
<!-- BEGIN lang_select -->
<td width="8" align="left"><img src="{lang_select_on.lang_select.LANG_FLAG}" alt="{lang_select_on.lang_select.LANG_NAME}" /></td>
<td class="genmed" align="left"><a href="{lang_select_on.lang_select.U_LANG_CHANGE}">{lang_select_on.lang_select.LANG_NAME}</a>
</td>
<!-- END lang_select -->
</table>
<div id="lang_select" class="js-sh-box">
tmp = 'lang_select';
</script>
</td>
<!-- END lang_select_on -->
<th style="cursor: pointer;" align="left" onclick="ShowHide('rss_feed', 'rss_feed2', 'rss_feed');">
<img src="{IMG_NAV_MENU_FEED}" alt="{L_RSS_FEEDS}" title="{L_RSS_FEEDS}" />
<a href="#" onclick="return false;" title="{L_RSS_FEEDS}" class="nav-menu-link"><b>{L_RSS_FEEDS}</b></a>
</th>
<td class="row5">
<div id="rss_feed2" class="nav-menu">
<td width="8" align="left"><img src="{IMG_NAV_MENU_RSS_FEED}" alt="RSS" title="RSS" /></td>
<td class="genmed" align="left"> {RSS_NEWS_HELP}</td>
</table>
<div id="rss_feed" class="js-sh-box">
tmp = 'rss_feed';
</script>
</td>
<!-- IF NAV_MENU_ADS_BOTTOM -->
<a href="#" title="{L_SPONSORS_LINKS}" class="nav-menu-link"><b>{L_SPONSORS_LINKS}</b></a>
</th>
<tr><td class="row1">{NAV_MENU_ADS_BOTTOM}</td></tr>
<!-- ENDIF -->
</th>
<td class="row5">
<div id="sponsors" style="position: relative; padding-top: 0px; padding-bottom: 0px;">
<td class="genmed" align="left"><a href="http://www.mightygorgon.com/">Mighty Gorgon</a></td>
</table>
</td>
</table>{IMG_TFL}{IMG_TFC}{IMG_TFR}
</form>
delete the code and then copy this into nav_quick_links...
should work this time... and remember when hiding html it is
<!-- to start the close and //--> to close and must be on a new line
let me know if there is still a problem as it is such a big file and so many tags but in it hard to see where there could be a problem
#9 Wed 19 Aug, 2009 22:35 |
Inactive User
christmanrd wrote: [View Post] I still would like to know why I can not do this in the CMS. I thought it could be done that way.
CMS is DB driven, .tpl files are not.
And do me a favour, because I'm looking bloody stupid because I went straight to the problem and didn't realise that someone had been editing the file in question.
If you are going to edit files and create problems for yourself then I suggest that you either fix them yourself, or put the original back and edit it one thing at a time until you find out where you "broke" it.
#10 Wed 19 Aug, 2009 23:09 |
DWho
i was looking at it in PM.. so many edits it was all over the place... i sent what i thought was the file fixed as i heard no more thought everything was ok... was not till i saw this post... i realised it was about the same thing...
#11 Wed 19 Aug, 2009 23:16 |
Inactive User
Thanks, next time I'll be more wary. But you would also be aware of what my philosophy is? "You break it" - "You fix it"
#12 Wed 19 Aug, 2009 23:39 |
DWho
yeah i think you are right... LOL
#13 Wed 19 Aug, 2009 23:41 |
christmanrd
Line: 555
Char: 13
Code: 0
Thanks,
Dave
In my original question, I had no idea what was going on or how to fix it. I did not realize that it was the .tpl that DWho fixed for me and forwarded to me through PM around Mon 17 Aug, 2009 09:54. I uploaded it to my server. It didn't even cross my mind. If I would have this post would not have been made. I trusted DWho and still do. They just did not connect in my mind because of that trust. I thought something else was wrong.
I normally use FireFox and it was not showing anything there. Yesterday, I opened IE and noticed the problem. There are quite a few questions that I have posted on these boards because there are problems that I am trying to resolve. When I discovered the problem, I posted it yesterday at 1536hr EST.
This morning I got up and started working and answering responses to my posts. In a post at 10:15hrs, I stated:
Quote: That's great. One question. Am I to find this in the index.php? I looked but I do not see anything that resembles what you submitted. It looks like it might be in the nav_quick_links.tpl
That's when it connected.
It was not until 1515hrs EST that I received the PM from DWho. Sorry, but all day I have been back and forth from my office to my shop trying to make a living. By the time I rec'd DWho PM the topic was already being discussed in here.
I apologize again for my ignorance. I am not the expert here at all. I am just a user trying to use this great script and learn it. I most definitely appreciated everyone's help. You guys are #1 with your support.
#14 Thu 20 Aug, 2009 00:07 |
DWho
not a problem as long as you got it sorted now...
#15 Thu 20 Aug, 2009 01:28 |
| Link this topic |
| URL |
| BBCode |
| HTML |
