Hello. I've read some topics that I found with "Search" but I don't find that I search. I want to add a button for MegaVideo. I've used the same codes that I used in 1.2, modifying that's necessary. The marks "[megavideo]ID[/megavideo]" work fine, and I can see the video, but the buttons don't work (when I press the button, may appear a window asking me for the ID of the video, but the window doesn't appear... Nothing happen). What should I do? What line in what file should I check?
Thank you and sorry for my poor English.
SOLVED Adding BBCodes In Icy Phoenix 1.3.0.53
Subject: Re: Adding BBCodes In Icy Phoenix 1.3.0.53
best way to do this is to look for the way the youtube button is added to the bbcode and replicate it to fit with megavideo..
i have never added a button to bbcode but if I did that would be the way i would do it...
hope that helps
:mrgreen: :mrgreen:
hope that helps
:mrgreen: :mrgreen:
Hello and thanks! Youtube button have a "special code", I explain: All the BBcodes have a similar code, but Youtube have a very different code... I don't understand youtube's code XD, so I can't fit it to megavideo... :cry: .
Youtube's code is the same that megavideo's code in all files except includes/bbcode.php. Is in that file in what youtube's code is very different that others.
I need help with that...
Excuse my english :oops: .
Thanks!
Thanks!
Did you add the url functions to /templates/common/js/bbcb_mg.js ?
Yes... I check those lines again, but are OK... I think that I should add anything in other file (I don't know what) to do it work...
It appears that you have script error somewhere. :(
Please post the Megavideo ID full HTML script that requests the video you are trying to add - And IF I get time - I'll try to do a walk through. ;)
Here is the "function" in templates/common/bbcb_mg.js:
And here is the code that add the video in the post (includes/bbcode.php), but I see the video, I need the button :cry: :
I think you want these codes, if I'm wrong and you want other codes, just tell me.
function BBCmegavideo()
var FoundErrors = '';
var enterURL = prompt(s_megavideo_insert, s_id_insert_tip);
if (!enterURL)
FoundErrors += s_id_insert_error;
if (FoundErrors)
alert(s_gen_error + FoundErrors);
return;
var ToAdd = "[megavideo]"+enterURL+"[/megavideo]";
PostWrite(ToAdd);
if (!enterURL)
if (FoundErrors)
return;
PostWrite(ToAdd);
elseif ($tag === 'megavideo')
$html = '<object width="640" height="480"><param name="movie" value="http://www.megavideo.com/v/' . $content . '.800360084.3" /><embed src="http://www.megavideo.com/v/' . $content . '.800360084.3" type="application/x-shockwave-flash" width="640" height="480"></embed></object><br /><a href="http://megavideo.com/?v=' . $content . '" target="_blank">Link</a><br />';
Moved to:[DOC] Add Video BBCode And Buttons To The Editor. (Walkthrough)
Maybe a staff member will add a link to it when they move it from General to the Docs forum.?
I don't understand you. The forum is legal, when it is open you can see it. Some users tell me if I can add MegaVideo BBCode because they have premium accounts and they prefer upload their videotutorials there (it's a webpage for "repair" informatic problems). I don't know if other users of other forums use MegaVideo for other things, but the users I refer use MegaVideo for legal purposes, so please, don't think bad about me.
I will try to repair the code. Thank you very much.
Phess,
I said for this type of access.
No matter what video code I put in the post, it always took me back to the same video with adverts etc, etc. So in reality I couldn't fully test what I did.
That's why I said "I wouldn't have bothered".
Thank you very much and excuse the double post. Finally, it works! I forgot add the line "$js_lang['s_megavideo_insert'] = 'Please write Megavideo file ID'; ". When you post the code, I check (another time XD) my code and I saw that I forgot add this line. Thank you very much, Lopalong. And thank you DWho, too.
P.D.: Sorry, you answer while I'm writting :P.
Subject: Re: [SOLVED] Adding BBCodes In Icy Phoenix 1.3.0.53
You're welcome - It's always easier this way than trying to work things out one post at a time. ;)
Generation Time: 0.0848s (PHP: 22% SQL: 78%)
