Post problems to upgrade
hi guys i have problems
Template->make_filename(): Error - template file not found: portal_page_tailcenter.tpl
Template->make_filename(): Error - template file not found: portal_page_headerleft.tpl
and i go to ACP:
Warning: mysql_connect() [function.mysql-connect]: User s038dba2_ktm already has more than 'max_user_connections' active connections in /home/s038dba2/public_html/forum/includes/db/mysql4.php on line 53
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in /home/s038dba2/public_html/forum/includes/db/mysql4.php on line 626
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in /home/s038dba2/public_html/forum/includes/db/mysql4.php on line 627
Critical Error
Could not connect to the database
wh?
link http://ktmdesignz.com/forum/
Desing
KtmDesingz
[spoiler][img]http://i116.photobucket.com/albums/o37/_ktm_/Firma32.jpg[/img][/spoiler]
-ktm-Send private messageVisit poster's website
Post Re: problems to upgrade
        $this->db_connect_id = ($this->persistency) ? mysql_pconnect($this->server, $this->user, $this->password) : mysql_connect($this->server, $this->user, $this->password);
this is line 53
Desing
KtmDesingz
I think that "max_user_connections" is related to server
It's not an icy problem :S
ok... ¬¬
and this
Desing
KtmDesingz
were you using IP template when you get that error?
not... i use ca_aphrodite
Desing
KtmDesingz
that's the problem
your themes need to be "updated", templates files aren't the same as in xs
yes but i cant go to ACP to change themes because redirected to index
EDIT: is solved
Desing
KtmDesingz
Post Re: Problems To Upgrade
Have you changed the files by ftp? (don't know if it's like that cos I don't have did it)
My 2 IP Forums:
Post Re: SOLVED -problems to upgrade
To run Icy Phoenix with Aphrodite you need some more files... you'll have all of them with the final release...
