[SOLVED] Problem With Style After Update
Subject: [SOLVED] Problem With Style After Update
Hello,
I just made the upgrade to ICY 2.0. The installation works but now it seems that CSS files could not be found.
I downloaded and installed the new templates and set it as default.
What could be the problem? Is there something I forgot during the installation?
In contrast to the Forum Page, the ACP looks correct.
screenshot125
Subject: Re: Problem With Style After Update
go to ACP styles and clear&restore template cache
Problem is solved. There were old files (from ICY 1.3.x) in templates/default.
I deleted this folder and re upload it from the 2.0 sources.
Generation Time: 0.2073s (PHP: 8% SQL: 92%)
