Admin CP - > Hacks/Mods List:
Some type of error?
- Warning: opendir(./../docs/hl/) [function.opendir]: failed to open dir: No such file or directory in /home/aonserve/public_html/forum/includes/functions_hacks_list.php on line 74
- Warning: readdir(): supplied argument is not a valid Directory resource in /home/aonserve/public_html/forum/includes/functions_hacks_list.php on line 76
- Warning: closedir(): supplied argument is not a valid Directory resource in /home/aonserve/public_html/forum/includes/functions_hacks_list.php on line 87
Think its missing the docs/hl folder not sure exactly.
Next.......
Admin CP -- > DB Maintenance -- > phpBB Mysql Admin
error:
Next
Admin CP -- > DB Maintance -- > DB Update Generator
Solution: http://www.icyphoenix.com/viewtopic.php?t=914
Admin CP -- > Portal -- > Portal Configuration
Error:
- Template->make_filename(): Error - template file not found: admin/portal_config_body.tpl
Admin CP -- > Portal -- > Page Mangement
Error:
- Critical Error
- Could not query portal config table
- DEBUG MODE
- SQL Error : 1146 Table 'aonserve_main.PORTAL_CONFIG_TABLE' doesn't exist
- SELECT config_value FROM PORTAL_CONFIG_TABLE WHERE config_name = 'default_portal'
- Line : 81
- File : admin_layout.php
Admin CP -- > Portal -- > Block Mangement
- Template->make_filename(): Error - template file not found: admin/blocks_layout_list_body.tpl
Admin CP -- > Portal -- > Block Position Tag
Error:
- Template->make_filename(): Error - template file not found: admin/blocks_position_list_body.tpl
Admin CP -- > Portal -- >Block Variables
Error:
- Template->make_filename(): Error - template file not found: admin/blocks_variables_list_body.tpl
Admin CP -- > Security -- > Proxy & Agent Blocker
Error:
- Template->make_filename(): Error - template file not found: admin/ct_blocker.tpl
Admin CP -- > Security -- > Confirguration
Error:
- Template->make_filename(): Error - template file not found: admin/ct_config.tpl
Admin CP -- > Security --> Select Footer
Error:
- Template->make_filename(): Error - template file not found: admin/ct_footer.tpl
Admin CP -- > Security --> Logfile MAnager
Error:
- Template->make_filename(): Error - template file not found: admin/ct_logs_4.tpl
Admin CP --> Security --> Security Check
Error:
- Template->make_filename(): Error - template file not found: admin/ct_seccheck.tpl
Admin CP --> Security -- > System Check
Error:
- Template->make_filename(): Error - template file not found: admin/ct_systest.tpl
This is from the latest version, I've ran the sql update from the latest one and replaced my old ip files with the new changed files from the download.
And I've chmoded the proper files, basically what we have here is a alot of mis-coded file locations which can be changed but see i'm not really that advanced php expert. Hope someone can help me out.
If you guys have any more errors/bugs post below and if you have solutions too.
thxs
--Old time member
TheLastLegion
Dresden
Perugia
