Problem To Install Mars Attack
Subject: Problem To Install Mars Attack
i have a problem to install mars attack . I do not know in which folder it goes put
Subject: Re: Problem To Install Mars Attack
inside mg_themes
Zuker wrote: [View Post]
inside mg_themes
:D after i try ................
What happend?
What happend?
hmmmmmm , i take mars attack in /templates/MG themes/ ok?
yes
dark_blue inside images folder
and rest of files must be replaces inside mg_themes
yes
thanks , i risolve the problem
Generation Time: 1.5343s (PHP: 1% SQL: 99%)
