Page Width
Subject: Page Width
Normally the page width is set in the overall header but I cant figure it out in IP. Im trying to make the black pearl template 1024 wide and centered. Can someone point me in the right direction
Subject: Re: Page Width
This code?
PS: Moving to templates.
Moved.
<align=center>
<table width="1024" height="768" border="0">
DATA
DATA
DATA
</table>
</align>
DATA
DATA
DATA
</table>
</align>
Moved.
Is that the code currently in the file or is that what I need to add? What file is that in?
The code to add.
You can change its width and height values, as the border one.
Post if it correct your problem.
wingzfan wrote: [View Post]
The code to add.
Just put in header the align and table open codes, and the close code in the footer tpl files
Ok I was able to adjust the size but it wont align center. I used
<table width="1000" align="center" cellspacing="0" cellpadding="0" border="0">
<td>
in the header and closed it in the footer. Anyone have any ideas why it wouldnt center?
<td>
because you have to center the table, with
Before the table starts
And in footer:
Just inmedetly after from the table closes
And in footer:
Ok did that
header:
Footer:
Still lines up on the left side of the page though. If I change the align to the right it goes to the right side but it wont center no matter what I try.
novice programmer wrote: [View Post]
Ok did that
header:
<body>
<align="center">
<table border="0" width="900" cellspacing="0" cellpadding="0">
<td>
<align="center">
<td>
Footer:
Try this:
Header:
Footer:
Header:
<table border="0" width="900" cellspacing="0" cellpadding="0" align=center>
Footer:
Still nada, its ok Ill just leave it full page. Thank you very much for your help though.
Do not use tables for that... use div instead.
OPEN this in header just after <body> tag:
and CLOSE it in footer just before </body> tag:
Let me know.
Remember that if you have 1024 you need a width which is less than 1024 otherwise page will stretch, because you need extra pixels to show its full width. 960 pixels it is usually enough even for including scrollbars.
Let me know.
Awesome that worked perfectly. Thank you so much man. BTW, you have done an amazing job with this system man. Im thoroughly impressed.
Generation Time: 0.0662s (PHP: 32% SQL: 68%)
