I'm using Black Pearl but I suspect this will be in any style.
when clicking on a UPI2DB function there seems to be a collumn for marking the posts since there is no checkbox under it and no activity dropdown either (like "delete marked").
I think we should remove it.. unless it would get a function again in the near future :wink:
Useless Mark Collumn
Subject: Re: Useless Mark Collumn
sorry Josh but i dont understand what are you talking about...can you be more specific (for me) or made screenshoot so i can check what is it about
thanks
thanks
The last +3 months I'm missing alot of tools and addresses that are on my main system because I'm on a borrowed laptop, and in no condition to sit at the desk where the main system is located, so I can not make screenshots (printsreen is not working on this laptop)
All I can do is rephrase:
In the menubar with UPI2DB switched on (Posts: New • U (0) • M (0) • P (0)), if there are new messages you click the link and go to the list... then at the right side there is a MARK column.
It's empty and useless because there is no checkbox and no function to mark as read for example.
I hope this clears it up for you Limun ;)
you are right
i think something is wrong :?
but on my localhost its working see pic :shock:
BTW i have 1466 unred messages :mrorange:
The difference between the two forums you refer to is in the setting at the top of the page in breadcrumbs:
Search found 4 matches • Show topics only
and
Search found 2 matches • Show posts text
Then you have alot to do :LOL:
Seriously.. maybe you just now switched UPI2DB?
and
If not, there is a difference in the versions!
Joshua203 wrote: [View Post]
i think this thing is for MG :read:
BTW yes, i enabled UPI few minutes ago :mrviolet:
Another page having this collumn wrong:
http://www.icyphoenix.com/search.ph...owresults=posts
clicked in profile, to view your own posts.
I guess it would be easy to remove the collumn in the tpl files but if the check boxes should return then you are correct .. it would be for MG (this may take a while though because he's relaxing and having fun now :LOL: )
Limun wrote: [View Post]
Generation Time: 0.1585s (PHP: 12% SQL: 88%)
