Post Icy Phoenix Ratings And Ranks PSD
Hi All,
since I'm going to release the first RC of Icy Phoenix I've decided to starting to release even some customization package...
Here are the ratings stars and the ranks I have designed for this site.
The format is multilayer PSD so you can easily adjust them in Photoshop and then use the Save For Web feature to create your own graphic for your sites.
I hope you like it and you will share your work as well.
Here is the link:
http://www.icyphoenix.com/dload.php?action=category&cat_id=11
Enjoy Icy Phoenix.
Post Re: Icy Phoenix Ratings And Ranks PSD
Wow, Rank and Ratings PSD's, this is nice. I might even change the rank to like "Mysite Member"..
Is there a IP logo PSD? I always had to make a PNG transparent for a logo as well as new theme.
Green and red as in my theme, it matches swell with my site.
ShaythongSend private message
I'll create a PSD for the logo after the final release...
ok! VERY GOOD MIGHTY !
algs163Send private message
Luca,
Would it be possible to get a PSD of the avatars you have in the avatar generator?  I would like to add some of my own personal ones to my site.
Round11Send private messageVisit poster's website
Here are some of them.
The others are only different pics insite
Thanks!  That's exactly what I needed!
