I need a little help and I thank everyone in advance for any assistance
1. I want to move / remove the ACP link at the bottom of the page and can't seem to figure where to find it in 2.0
2. I want to get the user name from the user on a custom page so I can have it customize some responces. Ex. User goes to the page and it says Hello to the User by User Name.
3. I would like to look into the idea of allowing admin to change their user name for RP purposes. I could do it in the old version but I am still gettin gused to 2.0 any direction to look at here is appreciated but 1 and 2 are the big important ones.
I Have 3 Tasks I Want To Complete
Subject: Re: I Have 3 Tasks I Want To Complete
1. The hook for the Admin Link is in -> overall_inc_footer.tpl
2. Add the 'USER_NAME' => $username, var to your custom page.
And also add the language vars that you want to use in your "Language" file.
Awesome Mort, thank you. When I get things done I'll put up a mod direction 8)
With question 3.
Why not just create another user NAME and give it "Admin" permissions, and use that name say for yourself - Because if you change or keep changing the "Admin" name it will only need to confusion.
Besides - When you log in as "Admin" instead or your "PR" name you'll probably feel TWICE as powerful! :LOL:
Generation Time: 0.9476s (PHP: 3% SQL: 97%)
