Hi all,
Since last upgrade, i have so many unsolved items, they are relate to upload and download. This is 1 of them, I attach the media file from posting.php using attachment mod. at the end of upload, it gives me this error. What is this mean? or how do i fix it?
DEBUG - Attachments - Tried To Upload Empty File
Subject: Re: Attachment
This problem us usually due to file size.
Please tell me the size of the file you tried to upload.
Greets!
Greets!
Try to create a folder called tmp inside /files/ directory and give it CHMOD 777 permissions.
Greets!
Greets!
sorry KasLimon for being so slow, can you give me more info? Thank you,KasLimon wrote: [View Post]
I read once that PHP needs a tmp directory to upload big files.
If you could create files/tmp/ directory (relative to your Icy Phoenix root) and give it CHMOD 777 permissions it maybe solves it.
It's just an empty directory :mricy: Create it
Greets!
Greets!
http://www.icyphoenix.com/viewtopic...hlight=download
Thank you,
wow, I can't undersand , but that fixed it. Like i mentioned above "this is 1 of them" , will this fixed the download?KasLimon wrote: [View Post]
Thank you,
Try to create pafiledb/uploads/tmp folder and give it chmod 777 :mricy:
It maybe gets fixed... :mricy:
I am so sorry. Now i am getting this error message after i upload it.
Wow Kas I didn't know that...
I'm moving this topic in Docs.
Thanks for sharing.
Thanks for sharing.
Generation Time: 0.1543s (PHP: 13% SQL: 87%)
