CUSTOMIZATION - Create New Pages And Add Custom Vars. IP V1.2.027*
Inactive User
Subject: CUSTOMIZATION - Create New Pages And Add Custom Vars. IP V1.2.027*
Note: This is no longer called a "MOD" by any particular Author - All it is are a set of standard instructions for creating a phpBB Page.
:shock:
If you are thinking about adding Custom Pages - Be strongly advised NOT to make any Typo's while you are doing it. :mrorange:
The Instructions for IP v....27c:
The Sample template.php File:
Sample variables.php:
Sample Finished template.tpl:
You ARE of course allowed to use Normal Markup as well. :woot:
What the Finished template.tpl Translates to:
:shock:
Subject: Re: Create New Forum Pages And Add Custom Vars.
Nice and useful documentation Lopalong,
thanks a lot.
hi again Lopalong
does this work with icy 27c
and would it be possible to make another links page
if you could would you have the control panel for it in ACP
i want to turn another links page into like this one i made on my test forum
so i can advertise peoples banner ads for them
shot
thanks bloke
hi
found add a page in icy 27c :oops:
and you can change settings to do what i wanted and have the best of both worlds
mighty gordan your icy 27c is tops mate! im always finding something new and you can
change things to suit yourself, i got a banner and link script from changing a couple of your settings
and adding a site page
the only problem is i can only add banners to your exact sizes , but i can work with that
for now. i would like to know if banners could stay there original size if under site size
because admin has to add all links as banners have to be sized first so they dont streach
thanks
bloke
new page called advertisers with static banners
advertiser
home page scrolling banners which can also be put global on your forum page or any new page you make
portal
thanks
bloke
What you can do is removing image size so images will be automatically sized.
Remove this twice from links_block.tpl
width="{SITE_LOGO_WIDTH}" height="{SITE_LOGO_HEIGHT}"
thanks Mighty Gorgon
works just how i wanted it
cheers bloke :wink:
I have a relative problem to the operation of the script that I am creating! This guide is indeed most useful.
The first problem is like can make so that, since I manage all way variable $_GET[] when the URL is template.php visualizes me a menu and not the tpl without data.
According to problem he is the following one. Since the script opens a directory and all print me to video the rows to its inside as I can make that stamps me all rows and not only one?
template.php
template_body.tpl
av2s02ks
Thanks to all! :cry:
Nice , But how can i get the menu to appear in the left like all my other pages ?
go in your cms to the page you made and add blocks
you can add extral blocks to some of the other original pages as well
Hello there...
I'm currently testing the rc version and this mod does not work...
The error:
Fatal error: Call to undefined function phpdefine() in /home....blah blah/template.php on line 1
Any suggestions please?
Thanks in advance !
borbo wrote: [View Post]
Hello there...
The error:
Thanks in advance !
this mod can't work
in the rc and next release are some core variables of icy phoenix changed
you have to wait till lopalong release this mod for rc
Thank you for answering... i guess i'll wait then...
Regards
alex
Inactive User
Instructions for RC1 - Onwards, Have been added to the first post. ;)
I think I got it right! :P
Thank you very much Lopalong
you saved us a lot of time... :up:
Inactive User
You're welcome,
But also be aware that if you opt to use "variables.php" you will divorce all var strings from Icy Phoenix and in fact create a stand-alone page that runs under Icy Phoenix.
For example: If you want to add the location to functions_mg_online.php, then you would have to include some language strings in my_template.php and add those vars to either the lang_main.php or preferably create a new file "lang_extend_my_template.php" and add the lang vars to that.
The whole exercise of adding / creating a .php file as per the instructions, is that it should work with any .php application providing the access vars and permission strings etc, are changed to suit where ever you try to add it; and that includes the lang vars.
Generation Time: 0.2293s (PHP: 12% SQL: 88%)
